Old 02-15-2006, 01:18 PM
Jim Hand Jim Hand is offline
Performance Pontiac Author
Default Gain clearance for headers to oil filters.
Header/Oil Filter Clearance
I intended to include this tip in my book, but somehow overlooked it!
To gain some clearance with any headers or filters, elongate the two lower holes in the oil filter adapter. Widen them as shown on the photo (leave the top hole stock size) and it allows the entire filter assembly to pivot a surprising distance left or right at the filter. And there is plenty of overlap with both the oil holes and the gasket to allow proper oil flow, and sealing. I have run a similar mod for over 15 years and it has worked perfectly.
The two photos of the filter assembly show the amount of filter movement possible with this very easy change.
Name:	Oil Filter Adapter - 600.jpg
ID:	42544   Click image for larger version
Name:	oil filter - left - 550.jpg
ID:	42545   Click image for larger version
Name:	Oil Filter - right - 600.jpg
Old 02-15-2006, 03:13 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Great tip, Jim. Thanks.
One question - how much material do you recommend removing in each direction when slotting those lower mounting holes?
Regards,
"455HO" Lloyd
Old 02-15-2006, 04:55 PM
LLoyd,
This mod is sort of "as needed" in each case. If the filter is close to one pipe, obviously we need to move it away. And by "centering" the filter, intallation/removal is easier.
The photo above was of a "display" adapter modified for the photo. But it is pretty close to what I run and the metal removed is about 1/4 to 1/3 the 3/8" hole diameter.
Note that the slotting has to be made in an arc centered on the top hole, and not simply in a horizontal direction. That is shown by the marked lines near the pencil tips. Much of my work is done "as needed" so I don't have specific numbers for you. But I would not cut clear to the edge on either hole.
Jim Hand
Old 02-17-2006, 04:05 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Jim, thanks for posting that info.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 03-20-2006, 01:35 AM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
cool setup
Old 04-06-2006, 08:09 AM
Phil from Canada Phil from Canada is offline
I just finished removing my headers and my oil filter assembly. I only needed a tiny bit more room, the headers would have came out, and I could have left the oil filter assembly on. I needed about the amount I would have got with this mod. Next time I quess. Thanks for the tip.
Phil
1972 Lemans GT with 1977 W72 TA engine and manual transmission
Old 04-06-2006, 06:08 PM
P@blo's Avatar
P@blo P@blo is offline
Great idea Jim, Thanks.
Brent
Old 05-02-2006, 05:10 PM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
good idea Jim, I just might have to do that......
Speed kills, buy a honda.
Old 06-16-2006, 06:46 PM
SLICK1 SLICK1 is offline
Thumbs up
Thats real clever Jim! but for those intrested? I've found that a NAPA oil filter for a 1979 CADDILAC COUPE DEVILLE WITH A 425 ENGINE has the same threads that screw to the filter boss, and it also has a perfect match for the rubber gasket as well! (these particular filters are narrow and longer than the actual filter part number that comes up that is shorter and larger in diameter, which often interferes with the rear header tube.) HOPE THIS HELPS.
(see it in action)
http://video.tinypic.com/player.php?v=2sbpmkm
Old 03-18-2007, 10:00 PM
81 GP 81 GP is offline
I ran into a problem on my 81 GP when I modified a set of 65 gto headers to fit. The drivers side fit fine after denting the floor near the gas pedal but the passenger side needed # 2 pipe rerouted. After that the headers fit fine but the only way to change the filter was to remove the header. I too went with a Cadillac filter I found listed in the K&N catalog as a race filter. Fits great and have no pressure loss, no worry about remote filter line routing . Cost was about $13.00. Any other filter I tried had lower flow capacity which made me very nervous with a cold engine.
Old 07-15-2007, 03:21 PM
Z Code 400 Z Code 400 is offline
FWIW,
With Hedman #28150 Headers in a Second Generation F Body.....all that was required for adequate clearance was the PF-61 filter. I actually had plenty of clearance with the 'big' filter, but wanted to keep oil temps down as much as possible...Robert
Old 03-24-2008, 01:00 PM
old66tiger's Avatar
old66tiger old66tiger is offline
Jim just keeps going and going. Thanks for the valuable advice Jim! Will keep this in mind as headers are probably in my future.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
Old 06-10-2008, 02:09 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Originally Posted by Z Code 400 View Post
FWIW,
Yep. Iv`e used the PF61 on a 2`nd gen Trans Am with Doug`s headers and on a `71 A body with Super Comps with good results.
Old 12-23-2009, 09:54 PM
cnc's Avatar
cnc cnc is offline
Is the PF-61 the longer thinner filter or still the short stockey filter
I've looked online and it seems there are a couple of different pics???
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 12-27-2009, 11:56 PM
PunchT37's Avatar
It`s a little longer and thinner than the PF24.
Old 01-20-2010, 03:34 PM
fjohn fjohn is offline
Does anyone currently make an adapter plate to use a remote mount or will I have to make my own?
Old 01-26-2010, 11:20 AM
wheelspin's Avatar
Smile Welcome to the Forums......
fjohn,
Butler and KRE both manufacture a nice block remote filter adapter.
Les
Les Iden
Old 01-26-2010, 03:50 PM
David Holmberg's Avatar
I run the Butler adapter and it works great!
Boy this thread has had a long life.
Old 02-01-2010, 06:09 PM
Default oil filter adapter
Hey wheelspin, thx for the information. Just what I'm looking for. I just dont like the pipe threads prefer straight threads and an oring or crush washer seal. More clearance and less chance of leaks. might buy the kre and modify. The butler one is only 1/2" thick whereas the KRE is thicker and contoured aroung the fittings. Both are very reasonably priced and well built. I just dont like the pipe threads.
Old 11-12-2011, 08:10 PM
misterp266's Avatar
Here's the one I bought.....
http://www.nitemareperformance.150m....eoilblock.html
As David said, "Boy this thread has had a long life. "
" Darksiders Rule "
