Old 07-12-2004, 03:51 PM
shotgun shotgun is offline
PY Staff -Tech
In the Pypes kit there is a double flared pipe that gets cut in 1/2 to use to fit the system to headers.
I know the pipe is "cut to fit" because there are all sorts headers and they would need different length based on brand.
My question is,how much of this extension did you use?
Any 70/72 LeMans or GTO install would do.
Pictures would be great.The shots on this site don't show any good shots of the area I need to see.
Thanks.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
PY Staff -Tech
Thanks.
Old 07-13-2004, 01:49 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Not the greatest pic, but it's what you're asking for. This is my '71.
BTW - Others have asked about the thing connected to the plate in the middle of the X-pipe. It's the ground clamp to my MIG welder.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 07-13-2004, 03:48 PM
PY Staff -Tech
For my purpose that is a great picture.Do you know the length of the collector to the weld?
Old 07-13-2004, 09:19 PM
PMDRACER's Avatar
Went out to measure it. The Driver's side is 8-1/2 inches from the collector flange to the weld, and the passenger side is 6-1/4 inches long.
Keep in mind though that I am running 3" pipe. I do not have "collectors". What I did was go to the local muffler shop and got the flanges with a 3" hole, butted the 3" pipe to it, and welded it on. The flanges are 1/4 inch thick, so if you were to measure from the end of the header to the weld, add that 1/4 inch to both figures.
-RONALD REAGAN
Old 07-14-2004, 06:49 AM
PY Staff -Tech
Mine is 2 1/4.I was going to try to eliminate the collector and extension and replace it with the long 8" collector that flowmaster sells.Looks like I will come up a 1/2" short,story of my life
Old 07-14-2004, 06:50 AM
PY Staff -Tech
I mean 2 1/2,doh!
Old 07-21-2004, 08:36 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
My 67 only needed about 4". The shop that did the installation also tried to eliminate the spacer pipe. In fact they thought they were successfull until I heard a funny noise while driving. When they pulled the exhaust about 2" forward it caused the tailpipes to rub against the axle shaft and brake lines.
Old 07-28-2004, 10:43 PM
USAMuscle USAMuscle is offline
Hey PDMRACER how do you like the sound of that X-pipe on your car? I have a '65 Pontiac and I'm trying to get as many opinions as I can about how the Pypes X-pipe sounds on a a Pontiac before I buy one, or if I should stay old-school and use an H-pipe setup. I have a Pontiac 400 with Hooker long tubes in my car with a moderate Comp Cams 280H Magnum cam and I want it to sound like a real muscle car, but am concerned about the X-pipe because on my Mustang an X-pipe or H-pipe will really change the way it sounds. Thanks.
