Old 10-31-2018, 04:52 AM
Chris-Austria Chris-Austria is offline
Default Pypes Violator vs. Hooker Aero Chamber
Hi!
I'm wondering how the Aero Chambers would sound on my GTO compared to the Violators I have at the moment.
I really like the sound of the Violators, but they are kind of loud and I would like to try something that is a little less noisy (still powerfull) and maybe a little deeper sounding.
Also wondering if they flow good enough for my 462cui with about 500hp. (I'll go with 2.5" dual)
Any ideas?
Chris
Old 10-31-2018, 09:01 AM
se428bandit's Avatar
se428bandit se428bandit is offline
I have a few video with Aero chambers in 2 1/2 and 3 in on my Ventura. Engine is a 455 6X heads, Crower 60919 cam.
Long branch manifolds and 2 1/2 exhaust and no X-pipe,
https://youtu.be/pUM9uhVicNA
Hooker headers, 3 in exhaust with X-pipe
https://youtu.be/z_pQviGPQSg
Same 455 but with 197 heads, HO manifolds, 2 1/2 exhaust with X-pipe and Summit #632501 mufflers (Magnaflow knockoff).
https://youtu.be/eOg3KG1d_lk
Old 10-31-2018, 09:44 AM
Lee's Avatar
Lee Lee is offline
I had a SBC Camaro on the chassis dyno a couple years ago. It has 3" Aerochambers on it. The car had some issues, but it still put over 400hp to the wheels.
I liked how they sounded. I'm considering them to eventually replace the RacePros on my Cutlass.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 10-31-2018, 09:57 AM
78w72 78w72 is offline
if the violators are too loud i would suggest going to race pros or dynomax ultra-flo, both are straight through for performance & quieter than violators.
Old 11-02-2018, 03:14 PM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
Aerochambers, 2 1/2 duals with H-pipe, tri-y headers and a 461 with iron heads.. i have no idea about the compression or cam in it.
https://youtu.be/lCV75wWe6lA
Same block but with regular headers and flowmasters dumping at the rear axle
https://youtu.be/3FFBgGdZwgU
The full exhaust and aerochambers made it a lot less noisy
1968 - Pontiac GTO
Old 11-02-2018, 04:12 PM
JLMounce JLMounce is offline
462, KRE D's 3 Tube Hedman's, 2.5" Pypes X with Violators.
https://www.youtube.com/watch?v=iiIoMZAdpWs
The Violators are loud, certainly not for the faint of heart.
-Jason
1969 Pontiac Firebird
Old 11-02-2018, 08:38 PM
Thanks a lot! I want a deep tone.. loud is okay, but not too loud.
Anyone has Magnaflows on his Pontiac? Just to compare them.. they are easy to get where I am but I guess they don't sound like a muscle car should?! (too modern in my opinion.. but there is no one around that has them on it so I cannot tell for sure)
Old 11-03-2018, 12:22 AM
If you’re looking for a deep traditional muscle car tone you’ll want either a non-crossover system or an h pipe. Pick a chambered muffler like a flowmaster 40 or something like a dynomax super turbo. Those will provide that traditional muscle car sound.
Anything with a straight through design and an x pipe is going to provide what you might consider a modern tone. I hear people say it sounds like a NASCAR.
-Jason
Old 11-08-2018, 08:56 PM
1funride 1funride is offline
I just installed a 2.5" magnaflow x pipe twin muffler system on my firebird 400. The mufflers are 14" I believe. Idle is quiet and low, muffled sound with out the chamber muffler hollow or high pitch sound. At cruise it is quieter as well and thank god no mind numbing drone like the flow master thunder america muffler. It is far from quiet during hard acceleration, maybe even louder than flow master exhaust. It comes down to personal preference, but for me, the drone had to go.
Old 11-21-2018, 12:49 AM
71 T/A 71 T/A is offline
I had Aerochambers on my 69 GTO but now I have 14" AP Exhaust Xlerators and they sound great with x crossover and 2.5" pipes.
Old 12-10-2018, 12:25 PM
RocktimusPryme's Avatar
I have magnaflows on mine. Very happy with them. Mild at idle, they get pretty loud when you hit the throttle.
https://www.youtube.com/watch?v=as5qp3G0WCA
Old 01-02-2019, 06:42 PM
leeklm's Avatar
leeklm leeklm is offline
Always feels like exhaust questions are like asking what your favorite color is my gto originally came with 2.5 magnaflows with X and a 450hp engine and headers.
I always felt it was louder under light acceleration than I wanted, and was somewhat irritating to me. Not obnoxious, but I only wanted that much noise when hammering it! Installed the 14" dynomax super turbo was was much happier.
I never did try the above setup with the 600hp combo, which went to the 3" setup with ultraflows.
Sent from my SM-G965U using Tapatalk
