Industry Stuff new repro's, updates, other info.
Old 09-23-2019, 10:26 PM
Red Box Rebel Red Box Rebel is offline
Cool Anyone Remember Rubber Trunk Mats? '68 GTO
When I bought my first GTO in 1974 it was a '68 GTO and it came with a real rubber trunk mat with a black & White hounds tooth pattern.
I am wondering why I cannot find a new rubber trunk mat. With all the GTOs and other Pontiac family A-Bodies and F-Bodies out there, you would think SOMEONE would reproduce the RUBBER trunk mat.
So, everyone needs to call the major parts houses that sell A-Body parts and ask them to find a supplier for real rubber hounds tooth trunk mats.
Rubber is just nicer than vinyl. If someone still makes them, please let me know.
Thank you
The Following User Says Thank You to Red Box Rebel For This Useful Post:
Old 09-26-2019, 07:45 PM
JimFB400HO JimFB400HO is offline
Have you looked at the NPD mats?
C-TMR-415AA Trunk Mat Rubber Aqua And Black Houndstooth 1-Piece
and
C-TMR-415AG Trunk Mat Rubber Gray And Black Houndstooth 1-Piece
Old 09-28-2019, 09:29 AM
dhutton dhutton is offline
Great way to rust out your trunk floor trapping moisture. Trunk mats are a bad idea imho.
Don
The Following User Says Thank You to dhutton For This Useful Post:
Old 10-02-2019, 08:38 PM
bkmont's Avatar
bkmont bkmont is offline
Have you tried these guys?
https://www.ebay.com/itm/1968-Pontia...AAAOxyW7tRh09b
The Following User Says Thank You to bkmont For This Useful Post:
Old 10-27-2019, 09:07 PM
Originally Posted by bkmont View Post
Thanks. I will check it out!
Old 10-27-2019, 09:08 PM
Don
Sorry, but I respectfully disagree. If you have water getting into your trunk, you have bigger problems than having a rubber trunk mat.
Old 10-28-2019, 08:46 AM
I was referring to condensation. Constant cycles of heating and cooling will cause moisture to accumulate under the mat. It has nothing to do with leaks....
Don
Old 10-28-2019, 12:31 PM
unruhjonny's Avatar
Many years ago, I found a nearly mint rubber trunk mat in a 1970 full sized (Canadian) Pontiac;
I bought it, and cut it to match the stencil of a 1973 Firebird trunk mat.
I recently threw most of it out because it had fallen apart... I kept a bigger chunk of it though to compare against my intended eventual replacement mat.
1970 Formula 400
Old 11-01-2019, 07:33 AM
chuckies76ta's Avatar
You really need to listen to Don. He's right about rubber mats causing rust on the trunk floor. The rubber doesn't breathe.
I've seen it first hand. Causes tiny rust pin holes. Whole trunk floor had to be replaced.
Old 11-01-2019, 04:53 PM
Cool Dry, no Olives and certainly not stirred or shaken!
I do not doubt that he is correct, but I like the rubber over the vinyl and can keep the trunk floor in rust free condition with the proper coatings. Where I live in Texas is a dry enough climate that we do not have the rust and humidity problems they have in Houston and the Eastern part of the USA.
Old 11-23-2019, 12:02 AM
1965gp 1965gp is offline
Your not BS’ing about the humidity in Houston. There are days I can go in the garage and the entire floor is wet. This is with an epoxy coating so I think the condensation just lays on top rather than soaking into the concrete
Old 11-24-2019, 10:27 PM
I put the trunk at in my 72 Firebird that I bought from Ames and was surprised that it had a jute backing? I would think that would retain water and cause rust problems later on? Is that what was originally offered?
Old 11-25-2019, 01:48 PM
unruhjonny's Avatar
wow!?
I thought that the trunk mats were the same through to 1972;
I have only two good points of reference;
1) three owner, single repaint only, but otherwise completely original 1971 Trans Am
2) a painfully original 1970 full sized Pontiac that I removed the trunk mat from
both were a thin but heavy, rubber mat with no backing.
The second example, I actually bought, and used a 1973 Firebird trunk mat as a pattern to re-cut an place in my car.
I know that by 1973 the trunk mat should have been a jute material, at least it was that way on Firebirds.
A couple years later the material changed again to a thinner rubber skin backed black "carpet" trunk mat (I always liked these ones).
1970 Formula 400
Old 11-25-2019, 10:30 PM
I mean it looks nice and honestly the only water the car will see is from washing so it should be fine. I was just surprised that was a factory option
Old 09-10-2020, 08:36 PM
A great product would be a houndstooth carpet, no rubber.
Old 09-10-2020, 09:32 PM
Firedup6975's Avatar
Don
This happened to me. Moisture got in my tail lights, and started rusting my trunk floor. I caught it in time, and cleaned it up, and re sprayed with spatter paint. I no longer use the mat. I put a blanket on the trunk floor now for my chairs and cleaning tote that I can easily remove or it will absorb moisture and I can simply hang it out to dry and let the trunk air out.
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
Old 09-13-2020, 02:10 PM
gokitty gokitty is offline
To combat the heat/cold condensation problem,I purchased an inexpensive (Big Lots,Walmart,etc) velour/soft blanket. Laid it under the the vinyl repop trunk mat and cut it to pattern after the vinyl mat. Water no longer is trapped...the blanket "breathes" and the blanket is not visible. I hang a water dessicant bag (Lowes,etc) from the trunk rod(s)to absorb water vapor and replace it when necessary. Result? Dry trunk. No rust.
The Following User Says Thank You to gokitty For This Useful Post:
Old 11-17-2020, 02:37 PM
lust4speed's Avatar
The '65 Bonneville 2dr HT I purchased a few years ago was owned by a doctor and his wife in Sedona, AZ. Nice dry place and the car was rust free -- right up until I brought it home and lifted up the rubber floor mat. Trunk floor was pitted through and will need to be replaced. The rear window wasn't sealed and the weekly car washes allowed the water to drip down into the trunk and under the floor mat where it never dried out.
Mick Batson
Old 11-28-2020, 03:30 PM
71 T/A 71 T/A is offline
I've used carpeting in 2 cars and it never rusts.
Old 11-28-2020, 05:00 PM
OG68 OG68 is online now
I'm trying to determine if my original 68 rubber mat is black and white or Aqua. I'm thinking Aqua but...
Late Fremont car with spare tire cutout.
Last photo is from early 80s
ID:	554953   Click image for larger version
ID:	554954   Click image for larger version
2007 Cadillac SRX
