FREE heads to a good home
Available for pick up in San Diego, CA 92117. Nothing special unless you need them for a restoration. I will never use them, I just dont like scraping Pontiac parts. Convince me (will not take much) that you have a use for them and they are yours.
#9773345 pair (1964), quite dirty but complete. Date code looks like G64 which does not make sense I know. Maybe they meant G064. I also have the right side big car exhaust manifold that goes with these (545470) if you want that. #140 pair (1967), D047, D117. Complete. Look to be in reasonable shape. #66 pair (1971), A051 stamped with a 66, A061 (next day) with 66 cast as usual. Very rusty, but will probably clean up. No valves, pressed in studs. bolted on guide plates. #46-single (1973), I believe this to be a 1973 and not a 1969 #46 because it has 6 accessory bolt holes in the ends. There is however no secondary 2H or 6H stamping that I can see. The date code appears to be I052, so it would be a very early 1973 and maybe they were not stamping them yet. |
I can't lower the price, but they are still available.
What price ??
fthree
I know is asking a lot but.. will you consider dropping them at any shipper?
Not sure if they will pickup this stuff |
I can do that within reasonable distance. I don't really have anything to pack them in. Which heads were you interested in?
