#68 Head on a 70 GTO
Was there a #68 head used on a 70 GTO 400, the block is a YS but the head a 68, I thought only 12 & 13 where the only heads available for the standard 400?
On a 1970 GTO "YS" 400, the correct cylinder head casting is #13. #12 castings were used on 1970 RA III's.
Can't recall ever even hearing of a #68 casting head.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
I would re-check that code.
Possibly it's a 1 and a 3 being mistaken for the 6 and 8?
Possibly a '71 455 "66" casting.
Boy, a 400 would be a real barn burner with THAT compression!
WT's used #12s.
Heres a picture, the seller says it a 68 also. He also claims its the original head. I don't have the date code yet. He said it was the low compression option/version. As far as I know, and you guys confirmed only 12's and 13's were on the standard 400.
What's the date code? They are on the upper RH corner in the picture.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Might be 66's...'71 455
Mike |
The pic is not great, date code would prolly help, but maybe a "6S". That would be a '75 455, or '76 400 / 455 head. Either 101 or 115 cc chambers - ugh!
BTW, there was no "low compression" option available on a '70 GTO. There was an economy option on GTO's which ran for three years, '67-'69, and included a 2V carburetor as well as a butt-kicking 8.6:1 compression. Here's a fairly decent head casting chart: http://www.angelfire.com/on/geebjen/heads.html
I think Lloyd is probably right.
Look for the date code and see if there is a stamped secondary code on the boss.
