#61
I had a solid roller made in 2008 for $500. All i did was send the stock cam out so the firing order could be duplicated. Two weeks later i was putting it in the motor.
You just have to be willing to spend the money. It stinks i know, but i'm glad i did it. The motor made 450hp to the wheels @ 15 lbs of boost! |
#62
Here are some pictures of it.
#63
Whoa!!! What did you put it in? Has been run?
#64
450 TO THE REAR WHEELS! Holy macrel there Sapphire, I want one.
fasteddy |
#65
#66
as I said earleyer in this post.BOP and Comp have blank round cam cores and can grind anything you need but I believe only for a roller.Tom
#67
Gary |
#68
What Tom was talking about before is having a V8 core ground for a 195. Only know of V8 roller cores being available. Best to check with manufacturers directly for availability. Dist and cam gears are the same in 195s and V8s.
#69
Yes that was to the wheels. It should make over 700 between 24-26 lbs of boost... I'll let you know what it makes when it turn it up... The funny thing is when you beat a big block chevy in a chevelle or camaro, they really can't seem to handle it too well when they find out its a 4 cyl.... AND a pontiac no less Lol... |
#70
I'm using a v8 dist in mine so the gear is the same. You just have to break off every other reluctor. |
#71
Its in a 64 gto.
Yes i ran it for the whole summer. |
#72
charlie66,
Thats bads ass! Have you had any problems with your block or crank holding up that much boost?
DragStarLeMans |
#73
LET'S SEE. A slant4, turboed, in a goat, ran all summer, not total boost!! Where do you run? Do you have a video? Or at least a picture? I would love to hear this baby sing. John
#74
I'm going up slow. Next is 20lbs then 25lbs and from there i'll see if i want to go any further. I really do want to see what it will make. One thing i left out is when i dynoed it , it wouldnt even idle . I had to pedal it just keep it running. I found out later that both valves were leaking bad on #3 cylinder. When i pulled the plug wire it didn't change the idle at all. So with this tune there is still more in it.. |
#75
Oh you know what. I have the chassie dyno video . I'll have to see how to down load it for you. |
#76
Charlie, great that you chimed in here. You deserve to have recognition for what you have built there. That thing is a monster. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
#77
You've been a great help to me with all of your advice.... |
