Old 12-12-2012, 05:53 PM
Transporter Transporter is offline
Default New 63 Lemans Project
Well since my Pete is in the paint shop, and I am waiting for sheet metal parts for my 62 GP, we decided to drag in the 63 Lemans that I got from Jerry (C5Farmer) a couple of weeks ago.
We took a vote and it looks like it will be Pro Street Gasser, if there is such a thing. I really didn't know what exactly I was going to do with the car until I took a good inventory of it.
But after looking everything over, and dragging out some parts I had under the bench,a narrowed, built 9" and some wheels and tires that I have had for a couple of years, it looks like I will finally get to use these parts.
The width of the rear and the BS on the 15x14 wheels comes out EXACTLY perfect for the width of this car, I literally could not have been better had I built the rear for this car.
I guess some days things just come together. LOL Some pics,
Name:	PETE ready for paint.jpg
ID:	305986   Click image for larger version
Name:	63 Lemans project 5.jpg
ID:	305988   Click image for larger version
Name:	63 Lemans project 4.jpg
ID:	305989   Click image for larger version
Name:	63 Lemans project 3.jpg
ID:	305991   Click image for larger version
Name:	63 Lemans project 2.jpg
Old 12-12-2012, 06:19 PM
jmt455's Avatar
jmt455 jmt455 is offline
That's gonna be fun!
Old 12-12-2012, 07:59 PM
beemergary's Avatar
Hi Transporter My new tempest hauler is a 84-359 Peterbilt. Just putting the final touches on a 1 1/2 restoration. On the sides done in old school lettering is going to read LITTLE INDIAN EXPRESS. Will be at Norwalk 2013 63 tempest coupe 421 SD-61 tempest wagon 421 SD 4 speed
Old 12-14-2012, 09:24 AM
Sounds cool Gary, hopefully we will see you there!
Old 12-14-2012, 02:44 PM
spartazoo's Avatar
spartazoo spartazoo is offline
I want to see some pictures of this rig... cough them up Mr. Beemer!
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 12-14-2012, 02:51 PM
Just can't beat Peterbilt's and Pontiac's lol
Old 12-15-2012, 09:05 AM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
Already doing a wheelie!!! Now that an omend. John
Old 12-25-2012, 10:52 AM
GaryK's Avatar
GaryK GaryK is offline
Default Met the Transporter
I had the pleasure of meeting Transporter (Stan) yesterday as he came East for the holidays. Thank you again for the trunk pan - see you again in Norwalk!
Gary
Old 01-04-2013, 06:20 PM
Well the holiday's are over back to work on the Lemans, making some progress,
Name:	63 update.jpg
ID:	308233   Click image for larger version
Name:	63 update 1.jpg
ID:	308234   Click image for larger version
Name:	63 update 4.jpg
Old 01-04-2013, 06:28 PM
Gary
Pleasure was all mine Gary, nice collection you have there, I won't tell everybody else that you are hording all of the early Tempest parts, lol
Stan
Old 01-04-2013, 09:28 PM
60man's Avatar
60man 60man is offline
Nice project..all of them..
I haven't seen one of those in-ground lifts in forever...sure brings back memories..
ECM member.
MANDRA
Old 01-05-2013, 10:28 AM
Thx 60man, yeah it's an oldie but a goodie, beats the hell out of working around the "arms" on my other lift.
As soon as we get the door openings braced, and the rockers in, we will weld the back half and tubs in and add the front frame rails. Then it's off to the blasters, and then onto the rotisserie to finish up floors and bodywork.
Stan
Old 01-08-2013, 06:46 PM
gutted the rockers and prepping them for the 2x3 tubing inserts, also got the inner fenders cut out and have to clean them up for the tubs.
Name:	gutting inner fenders.jpg
ID:	308899   Click image for larger version
Name:	Gutting rockers.jpg
Old 01-10-2013, 03:58 PM
Outside rocker panels going on today, should be able to get the 2x3 inner tubes in and welded up tom.
Name:	new rockers 1.jpg
ID:	309130   Click image for larger version
Name:	new rockers 2.jpg
Old 01-11-2013, 11:20 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
You got yourself a nice project. The more I see these 63's the more I want one. Looking forward to watching your build.
Old 01-11-2013, 01:13 PM
Thanks Mike, just seems like right now it is taking a ton of time to get everything laid out and old/bad sheet metal stripped away. As usual, after you get the paint scrapped off things look a little worst than thought.
After we get the back half tacked in things should start moving along better. But we ARE wanting this car done in time for Norwalk, so at some point things need to start coming together.
Stan
Old 01-11-2013, 06:55 PM
Here are some more pictures
ID:	309273   Click image for larger version
ID:	309275   Click image for larger version
ID:	309279   Click image for larger version
ID:	309280   Click image for larger version
Old 01-11-2013, 06:56 PM
Pics
Old 01-11-2013, 07:06 PM
Got quite a bit done today, rocker tubes installed, had to widen the rear clip 1.25" found centerline on rear wheel houses and located front 4 link crossmember. Located front factory spec holes and set crossmember square off of them.
Tom. will set tailpanel crossmember, and level rear tubes, finish all diagonal measurements and try and get front frame rails in. Pics
ID:	309284   Click image for larger version
Old 01-11-2013, 08:50 PM
ahnuld's Avatar
ahnuld ahnuld is offline
Good progress, keep posting pics of it coming together. Dan
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
