Old 01-15-2013, 05:19 PM
Transporter Transporter is offline
Sawyer got the rear ass. squared up and solid welded in today, also put in battery pocket supports, and should have enough room for a 20 gal. fuel cell "under" the floor.
Good news is it's coming along pretty well, bad news is we are out of tubing for the front rails, guess it's off to the foundry tomorrow!
Some pics of the progress,
ID:	309883   Click image for larger version
ID:	309884   Click image for larger version
ID:	309885   Click image for larger version
Old 01-15-2013, 05:33 PM
Couple more,
ID:	309890   Click image for larger version
ID:	309891   Click image for larger version
ID:	309892   Click image for larger version
Old 01-18-2013, 05:52 PM
Got the main frame rails in, still have to put the side braces in and side plate to the rockers. Will try and get it on the rotisserie on Monday, finish all welds, etc
ID:	310153   Click image for larger version
ID:	310154   Click image for larger version
ID:	310155   Click image for larger version
Old 01-18-2013, 06:49 PM
Couple more,
ID:	310160   Click image for larger version
ID:	310161   Click image for larger version
Old 01-18-2013, 08:44 PM
R 70 Judge's Avatar
The car looks great! Keep the progress pics coming
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 01-18-2013, 09:17 PM
blueghoast's Avatar
Looking good Transporter.
I only see one thing wrong It's should have three pedals. LOL
GT.
Old 01-18-2013, 09:19 PM
blueghoast's Avatar
Wondering are you useing the stock front suspention or going to a rack+pinion?
GT.
Old 01-18-2013, 09:35 PM
Thanks Judge appreciate it.
Old 01-18-2013, 09:38 PM
GT.
Actually, I will probably steal some of R70Judge ideas, I really like his stock cross member WITH the rack and pinion on it.
Old 01-19-2013, 09:28 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
She's starting to shape up. looks like it won't be too long and you'll have yourself a roller. Keep on trucking !!
Old 01-19-2013, 01:54 PM
Thanks Mike, appreciate it, just fooling around mocking some stuff up today. Should have the rear hung and in roller by Tuesday.
Couple shots of the mock up, looks like I will have plenty of room for the tires.
ID:	310243   Click image for larger version
Old 01-19-2013, 02:16 PM
mechanickeith's Avatar
I don't know Stan,,,,I think you need maybe 2-3 more inches of rubber under there!!! You sure you going to have enough power to turn those things??
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 01-19-2013, 02:22 PM
blueghoast's Avatar
Looks Bitching !!!!!!!
GT.
Old 01-19-2013, 05:07 PM
Keith, you really don't think the 195 will cut it? lol
GT.
Thanks BG, can't wait to get it all mocked up and then torn down to go to the blasters. Have some work to do on the quarter that the tree fell on, and need some rear lower quarter patch panels on both sides, still not sure what I am going to do there.
Stan
Old 01-19-2013, 05:15 PM
Well,,,,,maybe if it has a blow through turbo,,,,,,maybe.
Keith Collier
Tech advisor
POCI.org
Old 01-23-2013, 04:49 PM
Houston, we have a problem! Well we got the back all mocked up and everything will work out fine. So we moved to the front, which I was hoping was going to be a rebush the front end and repaint as we already tied the new tube frame into the old front stub.
However, after pulling the front end sheet metal off to go to the blasters, it became apparent that the front unibody structure was not in the best of shape and had several holes rusted though in key points.
So to make a long story short, I either had to patch what I had, find a new front clip to weld in, or just cut off the front end and most of the rusted out portions and replace with all new tubing.
The new front frame rails were ordered today, so I guess this thing will wind up with a full tube frame, not exactly what I wanted, but I think it will give me a better end product.
My own fault, I should have pulled the front apart first before assuming that it was salvageable. Just hoping it doesn't set us back to far.
Old 01-23-2013, 05:09 PM
GaryK's Avatar
GaryK GaryK is offline
Stan,
Have you considered welding in a later model subframe?
Gary
  #38
Old 01-23-2013, 05:19 PM
Originally Posted by GaryK View Post
Stan,
Gary
Hey Gary, yeah, I had several things going thru my mind yesterday, I guess the biggest issue for me was I really do like the factory fender wells and the way they look when finished, since we will probably go with a glass front end I really wanted to retain those so I didn't have to fab up struts for the front end, but I am just going to bite the bullet and do it right.
  #39
Old 01-23-2013, 05:40 PM
Cleaning up the old sheet metal,
Name:	front clip 1.jpg
ID:	310751   Click image for larger version
Name:	front clip 2.jpg
ID:	310752   Click image for larger version
Name:	front clip 3.jpg
  #40
Old 01-23-2013, 06:48 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
Default Project
Did you quit your day job???
