#81
There is a Physics process called the Heat of Combustion that comes into play with all fuels and the pressure and temperatures that they start out at. You kept the same fuel and Air/Fuel ratio but you changed the combustion process with the change in the compression ratio prior to the combustion event. So you actually did not keep EVERYTHING exactly the same except for the compression ratio. Food for thought. At the end of the day, sometimes just better to be happy with the new combination vs try and figure out completely why the numbers changed. Tom V.
#82
Maybe. haha...
My Half AN Injun..... |
#83
I can send you some links to the Heat of Combustion for Ethanol or you can do a search yourself if you have the inclination, Charlie.
Tom V.
#84
#85
Ok Thank you...
#86
Heat of Combustion Explained:
http://en.citizendium.org/wiki/Heat_of_combustion (There is a chart in the article with many fuels and values) I have posted below two fuels used in racing. Heat of Combustion Ethanol vs Methanol Methanol Molar heat of combustion - 726 KJ/mol Molar mass - 32.042 g/mol Density - 0.7918 g/cm3 Molar Volume - 40.467 mL Heat of Comustion - 17.94 KJ/mL Ethanol Molar heat of combustion - 1367 KJ/mol Molar mass - 46.0688 g/mol Density - 0.789 g/cm3 Molar Volume - 58.388 mL Heat of Comustion - 23.41 KJ/mL Tom V.
#87
Im not sure where E85 fits in with all those figures ..
Im trying to learn in comparison how different the to different compression ratios really are besides the psi factor. Seems to me when you find the right psi where the two equal the same out come in compression ratio after boost there very similar to tune.. In my case it seems things go south at 27 psi though .. I find this very interesting that the chart I made shows the same thing....
#88
Charlie, that is nice of you to share your real world experience on your two different compression combo. I wish I would have read your chart when I was at the beginning stage of building my first turbo conversion. That chart you have made will be helpful for the guys who's thinking on building a boosted Pontiac. Good luck and happy Boosting..
#89
Its going to be a monster . You should make a thread about . Everyone will be interested . I guarantee it !
#90
Stan
#91
Charlie,
I am not sure why there is a difference in are calculations. This is what i get. Stan 8.4:1 CR psi -- effective CR 10.00000 14.116 11.00000 14.687 12.00000 15.259 13.00000 15.831 14.00000 16.402 15.00000 16.974 16.00000 17.545 17.00000 18.117 18.00000 18.689 19.00000 19.26 20.00000 19.832 21.00000 20.403 22.00000 20.975 23.00000 21.546 24.00000 22.118 25.00000 22.69 26.00000 23.261 27.00000 23.833 28.00000 24.404 29.00000 24.976 30.00000 25.548 31.00000 26.119 32.00000 26.691 33.00000 27.262 34.00000 27.834 35.00000 28.406 36.00000 28.977 37.00000 29.549 38.00000 30.12 39.00000 30.692 40.00000 31.263 41.00000 31.835 42.00000 32.407 43.00000 32.978 44.00000 33.55 45.00000 34.121 46.00000 34.693 47.00000 35.265 48.00000 35.836 49.00000 36.408 50.00000 36.979 ========================== 9.8:1 cr psi -- effective CR 10.00000 16.469 11.00000 17.135 12.00000 17.802 13.00000 18.469 14.00000 19.136 15.00000 19.803 16.00000 20.47 17.00000 21.136 18.00000 21.803 19.00000 22.47 20.00000 23.137 21.00000 23.804 22.00000 24.471 23.00000 25.138 24.00000 25.804 25.00000 26.471 26.00000 27.138 27.00000 27.805 28.00000 28.472 29.00000 29.139 30.00000 29.806 31.00000 30.472 32.00000 31.139 33.00000 31.806 34.00000 32.473 35.00000 33.14 36.00000 33.807 37.00000 34.473 38.00000 35.14 39.00000 35.807 40.00000 36.474 41.00000 37.141 42.00000 37.808 43.00000 38.475 44.00000 39.141 45.00000 39.808 46.00000 40.475 47.00000 41.142 48.00000 41.809 49.00000 42.476 50.00000 43.143
#92
what do you mean when you say , not linked?
#93
My Half AN Injun..... Last edited by charlie66; 09-26-2017 at 01:09 PM. |
#94
Wow ! yours are much higher!
#95
I guess I do not understand what you charts does. I was thinking you were looking to see what boost at the old CR and boost at the new CR produced the same effective CR.
Stan
#96
I was looking to take my old compression ratio with a X amount of added boost pressure and compare that answer to my new ratio answer. Then compare at what psi both answers where at. So mostly it was a 5psi difference up until 27 psi where it started to grow more. This way I could keep the original tune I had as close as I could with minimal change.. And thats what ended up happening...
