Old 12-03-2022, 04:43 PM
beerslob beerslob is offline
Default 74 fuel pump
does anyone know where i can get a new fuel pump for my 74 trans am 400 w/o air? meaning it only has one 3/8 fuel line to the pump... everything i can find has a return line to the tank ...thanks for any help
Old 12-03-2022, 07:49 PM
Trevor78 Trevor78 is offline
So you want no fuel return line and no vapor return line?
Old 12-03-2022, 10:58 PM
my car just has a single 3/8 line just like my 75 no air ta . i can get that pump but the pump bottom is alot deeper on the 74 so the hard fuel line wont fit
the vapor line is on the drivers side and the fuel line is on the passenger side
Old 12-13-2022, 02:08 PM
is a 74 trans am 4 speed without a/c supposed to have a return line?
Old 12-13-2022, 04:39 PM
Held for Ransom's Avatar
A '74 "Trans Am" would have come with a 4 bbl carb. Which means it should have come with the AC40931 fuel pump and a return line (large body). AC40929 would be a 2 bbl. exc. vapor return line (small body). AC40930 would be a 2 bbl. with a vapor return line (small body).
A '75 "Trans Am" should have come the same way, don't know the number.
I do see a '75 fuel pump (AC41155) listed as a 8 cyl. eng. exc. vapor return line, but I would assume that would have come on a 2 bbl. eng. (small body).
So long, farewell.
Old 12-14-2022, 11:10 PM
thanks for the info, i couldn't find it anywhere... guess i have some more lines to buy, but at least i can find a fuel pump now
