Upgraded rear brake pads?
I posted this over at YB, but curious if anyone has experience using the high dollar brake pads. I always used them for circle track, which of course is a little different than how my 68 is used. Here is thr current situation...
Ford 9" with Explorer rear disc brakes in my 68 firebird. Manual MC with 4wheel disc distribution block. My braking generally seems ok with plenty of time to slow down after a drag run, but I feel like I could use more rear brake. I see that the generic semi metallic pads are only 1" wide, while the surface area of the rotor is 1.75" wide. Couple questions... -- does anyone know if a wider pad is available for the Explorer calipers? -- would a Hawk Ferro-Carbon pad (or other) provide more cold friction stopping power than a generic SM pad? Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
