Old 08-08-2003, 07:57 PM
RamAirJohn RamAirJohn is offline
*For those who are into originality and numbers*
If you have any spare's below, please let me know
1967 - 1968 Firebird Disc Brake Parts
HUB & DISC ASSY (2-pc Rotor)- 67-68 F, T w/D.B.
1381730 (orig. #)- 11" dia x 4.12"ht. 3901098 (replc. #)
CALIPER HOUSING (Inboard)- 67-68 F, T w/D.B.
5468364 (RH) 7/16" pipe, 5468363 (LH) 1/2" pipe
Casting # 5455530 -or- 5456008, "Delco Moraine" (Date Coded)
CALIPER HOUSING (Outboard)- 67-68 F, T w/D.B.
5456076 (RH/LH)
5455946 Casting # "Delco Moraine" (Date Coded)
LINING, FRT. BRAKE (PAD)- 67-68 All w/D.B.
5461058 (orig. #), 5469107 ('69 replc. #), 5470879 ('71 replc. #)
SHIELD, FRT. DISC BRK. SPLASH- 67-68 F, T w/D.B.
1381722 (RH), 1381723 (LH)
BRACKET, CALIPER MOUNTING- 67 T, 67-68 F w/D.B.
1381720 (RH), 1381721 (LH) (# stamped onto rear of bracket)
HOSE, FRONT BRAKE- 67-68 F w/D.B.
9791649 (RH/LH) (light org. ink-stamp near fitting..."9688-8A?")
BRACKET, FRT. BRK. HOSE to CALIPER MNTG. BRKT.- 67-68 F w/D.B.
9789431 (RH), 9789432 (LH)
BRACKET, FRT. BRAKE HOSE to FRAME- 67-68 F w/D.B.
9785915 (RH), 9785916 (LH)
PIPE, FRT. BRAKE HOSE to CALIPER- 67 F w/D.B.
9789425 (RH), 9789426 (LH) (1st type w/3/8" nut on btm.)
PIPE, FRT. BRAKE HOSE to CALIPER- 67-68 F w/D.B.
9789908 (RH), (2nd type on '67 w/7/16" nut on btm.)
9789909 (LH), (2nd type on '67 w/1/2" nut on btm.)
PIPE, FRT. BRAKE (Dist. & Swt. to Hose)- 67-68 F w/D.B. exc. P.B.
9791358 (RH), 9785928 (LH)
PIPE, FRT. BRAKE (Dist. & Swt. to Hose)- 67-68 F w/D.B. & P.B.
9791356 (RH), 9785927 (LH) exc. cruise cont., 9794068 (LH) w/cruise cont.
PIPE, M/CYL. to FRT.BRK.PRES. REG.(MTRG.) VALVE- 67-69 F w/D.B.
1384694
PIPE, FRT.BRK.PRES.REG. to DIST.SWT.- 67-69 F w/D.B.
3905573
VALVE, FRT. BRK.PRES. REG. MTRG.- 67-69 F, 68-9 T, G w/D.B.
3905525
BRACKET, FRT.BRK.PRES. REG. MTRG. VALVE- 67-69 F, 68-9 T, G w/D.B.
3912539
VALVE, RR.BRK. PRES. REG. MTRG. VALVE- 67-69 F/8 w/D.B. & A.C.
3908326
KNUCKLE, STEERING (spindle)- 67-68 F, T , 69 GP w/D.B.
9786397 (RH/LH)
Casting # on rear... 3916266 GM 54
MASTER CYLINDER ASSY- 67 F w/D.B.
5463492 (1.12" bore)
MASTER CYLINDER ASSY- 68 F w/D.B.
5459784 (1.12" bore stamped "FR").... Orig. #
5469357 (1.12" bore stamped "GA")
COVER, BRAKE MASTER CYLINDER RESERVOIR- 67-68 F, T, 69 w/D.B.
5455517 (w/Moraine Disc Brakes)
DIAPHRAGM, M/CYL. RESERVOIR COVER- 67-68 F, T, 69 w/D.B.
5455516 (w/Moraine Disc Brakes)
RETAINER, MASTER CYLINDER COVER- 67-68 F, T w/D.B.
5455518
**Please advise of any errors or if I've overlooked anything**
Thank you,
RamAirJohn
Eph. 4:32
Semper Fi
http://members.aol.com:/ramair68/gen1home.html
RamAirJohn
Eph. 4:32
Semper Fi
5456076 (RH/LH)
1384694
3905573
3905525
3912539
3908326
9786397 (RH/LH)
5455518
Thank you,
RamAirJohn
Eph. 4:32
Semper Fi
RamAirJohn
Eph. 4:32
Semper Fi
Old 08-13-2003, 05:07 PM
DanC's Avatar
DanC DanC is offline
I have two 4 piston calipers needing resto, but the cast number is 5455533. I thought these were for the '68 FB. Would you happen to know what they are for? They are availible if you want!
DanC
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 08-13-2003, 05:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by DanC:
5455533 <HR></BLOCKQUOTE>
Dan- What you have is probably correct. I'm still sorting through variations of the casting numbers for the Outboard and Inboard Calipers.
As with most parts, there were usually numerous changes made during production and in the years following to the service replacement parts.
Please e-mail to discuss what you have.
RamAir68@aol.com
Thanks,
RamAirJohn
Eph. 4:32
Semper Fi
RamAirJohn
Eph. 4:32
Semper Fi
