Heads, Blocks, a 455 and other parts
Love to sell this stuff to make room.....
Good head cores with valves, 4X-H stamp heads, date code D233, or 2nd set dated F043, 3rd set dated E074. 5C-4 stamp, H284. All are screw in studs. $90 pair. 7H-1 coded D272, #15's 1969 date, press in studs, $50. 1968 YC, 400 block, needs bored, dated F208 $250 1977 XA code short block, cast number 568557. 1976 YY code 400 short block, cast 500557. no oil pans. $75 each. 1977 400 TA block with bad crank, $50 400 Crankshafts, std size. $50 each. 1971 YC code 455 complete engine with #66 heads and barrel intake. not running. $600 Short and long tail TH400's w BOP bolt pattern $75 each. Will bring any of these to Fall Carislie on Thrusday or Friday. Can also ship. Thanks. |
Bump, open to offers on any....
400 short block
do you still have 400 short blocks?
Yep still ahve most of them.
Do you still have the 455? I am in need of a good block, mine is cracked.
All 4X heads ,YC 400 block, 400 cranks & 455 engine, all sold.
Any of the 76-77 XXX557 blocks $50. Any of the TH400 trans $50 each. \ Feel free to make offers..........thanks |
