Old 10-07-2021, 02:50 PM
NYGTO's Avatar
NYGTO NYGTO is offline
Default 1965 GTO Air Cleaner Foam Support
A fellow GTO acquaintance prompted me to show this foam support of the air filter for the 1965 GTO four barrel cars. My blue charcoal GTO still had this but I never saw one before. I was told the foam that wrapped around it didn't last and the one piece element replaced it soon after. Did 1966 cars have this part or did they already switch to the one piece filter?
Old 10-07-2021, 03:53 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
I’ve never seen that style of support for the old foam filters.
Below is the support screen that was in a box of goodies when I purchased my ‘65 GTO.
It’s the exact same construction as the Tri-Power screens.
You may want to consult with the GTO experts on this site.
ID:	574692   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 10-07-2021, 04:37 PM
NYGTO's Avatar
I think what I have is a well intentioned and constructed piece of folk art. Nice to see that sometime back when, someone took the time and effort to make it.
Old 10-07-2021, 07:46 PM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
NYGTO, that Zig Zag wire is for 60-62 Corvette Foam Air Filter.
Old 10-08-2021, 05:20 AM
NYGTO's Avatar
Todd thank you for responding, I appreciate the information.
Old 10-11-2021, 09:50 AM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Cool
Probably worth millions!
Old 10-11-2021, 10:36 AM
NYGTO's Avatar
FOR SALE:
A 1961 survivor Corvette needing a complete restoration but with some parts missing. Serious inquires only, please p.m.me. :--)
Old 11-13-2021, 12:23 PM
Canby GTO Canby GTO is offline
Default 1965 GTO air cleaner foam support
The spring support is the correct original that came with my 65 GTO with foam stretched over it. As I am an original owner, I replaced it with a paper element along time ago as the foam wasn't available then. I am sure I can still find it.
Old 11-13-2021, 01:06 PM
NYGTO's Avatar
Canby, are you referring to the one I have pictured?
Old 11-13-2021, 04:33 PM
Yes I am going to send you a couple ofpictures
ID:	577757   Click image for larger version
Old 11-14-2021, 03:40 PM
NYGTO's Avatar
Canby, thank you for providing the pictures and information. It's very helpful especially coming from an original owner. Hopefully some others can provide information to.
Old 11-15-2021, 04:15 PM
NYGTO's Avatar
Canby, I was wondering if these wire style foam supports came from a specific plant location(s) or month. My car was built in March 1965 at the Pontiac Michigan plant.
Any chance your GTO has the same assembly plant and date build?
Old 11-16-2021, 08:46 AM
Andre's Avatar
Andre Andre is offline
This certainly upsets the apple cart of something that was thought to be gospel! Exciting!
Old 11-16-2021, 09:53 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Interesting, I never would have guessed that was a factory installed part. Perhaps they ran out of the normal supports and they dove into the seat spring supply and made them to work. My original '67 support is more like what Chris shows above.
ID:	577972   Click image for larger version
Name:	Air Filter Screen with New Foam Element.jpg
Old 11-17-2021, 07:17 AM
Jeff Hamlin's Avatar
Default Interesting Indeed.
You would think the "Spring" design went away quickly due to allowing deteriorating foam element pieces to get sucked into the carb and the full screen came into play?
Just guessing here.
Old 11-17-2021, 08:10 AM
chrisp chrisp is offline
Do you remember if the original GM foam had any script on it ?
Old 11-17-2021, 10:58 AM
My GTO was built Jan 9,1965 in Kansas. As far as I know you can't get the foam filter anymore and so I used the paper filter that doesn't use the spring support.
Old 11-17-2021, 11:56 AM
Old Goat 67's Avatar
Yes, they had an AC logo I remember.
The Following User Says Thank You to Old Goat 67 For This Useful Post:
Old 11-17-2021, 03:01 PM
60sstuff's Avatar
Hi Gary,
I thought your ‘65 Blue Charcoal was a “second week of February” out of the PON Plant.
Old 11-17-2021, 03:49 PM
60sstuff's Avatar
Default Foam Filter Support
This is an interesting topic on the factory foam supports used in the early to mid-60’s.
As I mention above the 64-66 GTO foam supports were made of a “Screen” for the Tri-Power and the 4 BBL. as the MPC shows screen, not spring wire.
When I purchased my ‘65 GTO from the Original owner there was a box in the trunk with items that had been removed from this car decades earlier including the air filter “Screen” that I show.
Also the air cleaner base of my car shows service instructions stating screen for A 98 C filter and again shown in the MPC with the Screen.
It’s quite possible GM used various foam supports back in the day for a mass produced automobile.
My GTO is an 11A Baltimore built.
ID:	578009   Click image for larger version
