Old 07-12-2014, 06:07 PM
Rich-Tripower's Avatar
Default 64 no console shifter boot orientation
Next on the agenda is putting in the shifter hump and shifter boot. I'm assuming the boot goes directly on the hump metal, the carpet goes over that and the chrome trim ring goes on top of both. Correct me if I'm wrong.
Then the last question is, what is the orientation of the boot and trim ring? Does the one more blunt corner go toward the front toward the glove box or to the rear toward the driver?
This way:
Or this way:
ID:	369868   Click image for larger version
Old 07-12-2014, 06:24 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Both ways you show are incorrect.
Factory installed the ring and boot horizontally as seen in 64 sales brochure and same for 1965 as seen in second pic. I have better pics somewhere?
The single rounded corner to bottom right.
Name:	64 GTO 4 BBL.jpg
ID:	369870   Click image for larger version
Old 07-12-2014, 06:30 PM
Dick Boneske's Avatar
Here's how the shifter boot is oriented.
Name:	GTO Outside & New Mats 010.jpg
ID:	369874   Click image for larger version
Name:	GTO Outside & New Mats 013.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-12-2014, 06:32 PM
Ha! Would have never guessed it went that way. Glad I asked!
Old 09-18-2021, 10:10 PM
Tom Vaught's Avatar
Boost Engineer
Agree, even with a console it should go that way.
Tom V.
