Old 09-27-2021, 05:28 PM
dataway's Avatar
dataway dataway is offline
Default Window track fuzzies/weather strip
I bought some replacement weather strip that goes in the front of the side window channel. Got it from Ames, pretty much totally different than OEM but looks like it might work well.
However, this window channel, part of the vent window post/support has a metal channel rivetted in on the lower half where it is inside the door. This replacement weather strip is not going to fit into that ... must it be removed?
The OEM setup appears to have been two pieces, one metal backed rubber that fit into the channel above the door, and this larger metal channel that held the "fuzzies" inside the door.
This replacement is long enough to go from top to bottom ... but not unless the OEM channel is removed. Should it be glued in? It fits pretty snug in the channel (in the area is can go without removing the OEM metal channel) and has the location for the anchor screw at the top.
Any advice?
Old 09-29-2021, 07:39 AM
hakansan's Avatar
hakansan hakansan is offline
What part# and is it a 2dr ht?
`70 GTO, 370 hp, 3:90, TH400.
Old 09-29-2021, 11:48 AM
dataway's Avatar
Yes a 2 dr HT. No idea what part number it is, the replacement part was Ames F239B
Old 09-30-2021, 04:57 PM
hakansan's Avatar
Ok, The replacement fits -67 F-body and -68 A-body. For -68 A-body You need to cut it for proper lenght.
Håkan
The Following User Says Thank You to hakansan For This Useful Post:
Old 10-07-2021, 05:50 AM
dataway's Avatar
Where can I get the inner and out quarter window sweeps for my 68 GTO? I'm not seeing them in our Host's catalog.
The inner one that attaches to the inner quarter panel "door" panel.
The outer one that attaches to the body ... as seen in photo below.
Thanks.
Old 10-07-2021, 09:01 AM
Carousel72TRed's Avatar
Carousel72TRed Carousel72TRed is offline
I believe they are called rear quarter window chrome sash channels and you can order them from Ame's performance or OPGI.
Carousel72TRed
Old 10-07-2021, 12:16 PM
OG68 OG68 is online now
GT119A from Repops.
Complete set of inner and outer fuzzies,
The rears need a little manipulating to fit right. I found it best to lay it against the original to make the bends
Buy them from eBay seller calponres who has the best price.
https://www.ebay.com/itm/33399153775...IAAOSwi6tdLmTZ
2007 Cadillac SRX
Old 10-07-2021, 01:59 PM
dataway's Avatar
Done! Sweet, made in the USA.
Thanks OG!
