Old 08-28-2022, 01:56 PM
15bhardwick 15bhardwick is offline
Default Right turn on launch
Just got the car to the track Friday night for test and tune after 3 years of building. Rear end is solid brim joints on all 8 mounting locations. Rear lower bars are straight and not angled anymore. Top bars are still triangulated.
Spool. 2.5 degrees on pinion angle. Guessing 500 hp. Torque converter stalls close to 4,000.
Car drives straight down track under power but not launch. Car took a hard turn on the launch straight to wall. Had plenty of time to let off and turn but there’s an issue somewhere. Body roll is extreme right now but we have limited room for an anti roll bar and can’t mount a factory style sway bar since our lowers aren’t stock location
I’m thinking about getting a set of trick springs and possibly an air bag for passenger side. Any other recommendations?
ID:	597336   Click image for larger version
ID:	597337   Click image for larger version
ID:	597338   Click image for larger version
Old 08-28-2022, 05:28 PM
Tom Vaught's Avatar
Boost Engineer
Air Bag on the right side should help A LOT.
That launch is nasty. Air Lift Bag in right spring location will keep the right side of the car from body acting like a Submarine on the right side.
Tom V.
Old 08-28-2022, 05:43 PM
Old Goat Racer's Avatar
Are your slicks directional ? Maybe swap them side to side ? See if the car goes the other direction ?
Everybody knows somthin.
Nobody knows everything !
Old 08-28-2022, 06:17 PM
ta man ta man is offline
One pass or every pass?
Old 08-28-2022, 10:01 PM
Mike S's Avatar
Mike S Mike S is offline
An air bag will help in the right rear. It still will lean the harder you launch. The best fix is a good anti rollbar. They make nice weld in ones with rod links to the rear end. In my opinion that is the only way to get a level launch.
Old 08-29-2022, 09:26 AM
RJRjr's Avatar
RJRjr RJRjr is offline
Yeah, an air bag on right rear could help alot. I used one for years on my car when it started doing that once I got into the low 12's , high 11's. Went to a hr parts bolt on anti roll bar a few years ago. Works good. Also check that slicks are same circumference if you are on slicks.
Old 08-29-2022, 11:32 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Sometimes you can weld in a piece of tubing between the 4 link brackets or LCA brackets and use that to mount the bar low and run the links up to a cross tube on the chassis up high. I can tell you from race car and street car experience, the ARB is wonderful thing whether your going 9.20s or 11.20s
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 08-29-2022, 11:43 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I take it you've scaled the car already and have equal weight on both rear tires? Anti roll bar would help whichever way, either on the frame or rear end.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 08-29-2022, 04:59 PM
1972 Pontiac LeMans
Thanks to
Old 08-30-2022, 12:50 AM
It was 37 lbs heavy on driver side with me i the car
Old 08-30-2022, 12:54 AM
I like it! After welding in a cross bar up and slightly behind the rear end for the shocks there just isn’t much room at all with the stock trunk floor. This looks like it would fit. What brand is your anti roll bar in these pictures?
Old 08-30-2022, 08:42 AM
It is a Quarter-Max kit, the only thing I did differently is the cross tube for mounting and instead of using the bolt together tabs on the bearing housing we just took some tubing and fit it to the cups. They have a few different designs, this one was overkill but I liked the billet arms, and being able to remove the bar and the bearings to service it instead having the weld on arms style. I was just going to radius the mounting tabs in the kit to fit the cross tube but but my buddy who welded it up for me liked using the two pieces of tubing instead because he could space it where he wanted it
https://quartermax.com/heavy-duty-1-...kit-universal/
1972 Pontiac LeMans
Thanks to
Old 08-30-2022, 04:38 PM
Scott Roberts Scott Roberts is offline
Does your car look like this from the front..lol
That's a local guy Wayne Greens old car from 2001..
Old 08-31-2022, 09:59 AM
This was my old race car before and after we put the RJ-301195 ARB on it. The ARB install was the only change
1972 Pontiac LeMans
Thanks to
Old 08-31-2022, 11:49 AM
sdbob sdbob is offline
Back in 72 I helped a friend with a 454 70 Chevelle. He put bags in both springs. Inflated right rear the most. Car just sitting the right side was higher than left(drivers side). Just saying. He had an long asphalt driveway in Latrobe, that I witnessed numerous test hits! They worked.
Old 09-01-2022, 10:04 AM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Anti roll and you’re finished
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 09-03-2022, 07:04 PM
cgeise's Avatar
cgeise cgeise is offline
with no roll bay you need lots of pre-load on r/r what are your corner weights -- front and rear
Old 09-03-2022, 10:13 PM
Can I put preload on a triangulated 4 link with upper passenger bar? Or does that just work for parallel 4 links.
Installed an air bag and put 12 lbs in it. The squat isn’t quite as bad but still goes right. Car had a 1.58 60ft
Old 09-03-2022, 10:15 PM
This was when the car was almost finished so weights might be not exactly the same now but close. Me in it
Old 09-03-2022, 10:23 PM
Pics
ID:	597788   Click image for larger version
ID:	597789   Click image for larger version
ID:	597790   Click image for larger version
ID:	597791   Click image for larger version
