Old 04-06-2005, 01:21 PM
1157 motor head's Avatar
1157 motor head 1157 motor head is offline
would some one please help, i am about to paint the inside of my trunk for my 70 GTO. what color splatter paint belongs in the trunk of a 70??
thanks Jim
thanks Jim
Old 04-06-2005, 06:12 PM
tp's lemans sport's Avatar
tp's lemans sport tp's lemans sport is offline
Our host sells the correct color. Original parts group Has a full size picture of the can. I believe its GM reconditioning paint Part # 10511499. You can save a few bucks by going to GM Direct.com
1970 Pontiac Lemans Sport
1970 GTO Convertible
Old 04-08-2005, 11:08 AM
gtoformula's Avatar
gtoformula gtoformula is offline
There are several trunk spatter paint combos out there. Black with gray, black with green and black with aqua are the three that I know of. A 1970 GTO had black with aqua and, unfortunately, seems like the least likely to be in stock at local parts stores. You can get it from Performance Years.
Old 08-05-2006, 10:33 PM
norton70 norton70 is offline
what color should u start with before applying spatter...i am painting my trunk about 50% black...if the spatter is black with aqua...will the black spatter be seen? should i use grey in the trunk instead of black? I think this car used flat grey instead of black primer first, then laid down the spatter...then clear...looks good
http://216.178.81.108/forums/showthr...hlight=spatter
Old 08-06-2006, 12:18 AM
gtoformula's Avatar
Black with aqua specks is the only correct color for a 1970 GTO trunk.
Old 08-06-2006, 07:48 AM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
I achieved best results over black (por - 15) I used gray primer in some areas and the spatter was too light over it.
70 GTO 400/4SPD-13.97@102.31
Old 08-06-2006, 11:23 AM
are u saying the grey primer was good or bad...if we use black / aqua spatter...does it show up on the black primer...i would think the gray primer would be necessary after reading all the posts
Old 08-07-2006, 12:08 PM
4SLASH6's Avatar
just looks that with the gray I was adding another color to the mix (gray,black,aqua).
Old 08-07-2006, 12:46 PM
so should i use black or gray primer before the spatter?
