Old 05-03-2020, 01:07 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default ‘62 Pontiac Down Draft Tube
Anyone have a pic or diagram of one? I’m not sure where it would be or even what it looks like. Thanks
Old 05-03-2020, 02:30 PM
61-63's Avatar
61-63 61-63 is offline
There is a bracket that bolts to the rear of the head and then to the tube. The tube has a rubber ring on it as I recall where it mates with the valley pan.
Name:	mock up motor.jpg
Old 05-03-2020, 02:50 PM
Stuart's Avatar
Stuart Stuart is offline
61-63 is correct, there is a rubber ring where it plugs into the valley pan.
The whole thing can be replaced with a PCV valve if desired.
Old 05-03-2020, 05:33 PM
DiamondJim's Avatar
My 1962 GP has factory PCV. No draft tube. There is a small canister/filter vent? Bolted on the rear of the passenger head. It looks like it’s coming from the transmission. It has a hooked hose exited the top to open air.
Old 05-03-2020, 08:57 PM
Stuart's Avatar
I believe that's a breather tube for the slim jim transmission.
Old 05-03-2020, 10:07 PM
DiamondJim's Avatar
