Bezel wiper knob
Hi guys, seems i lost my screw of my wiper knob. So I need to find one. But also the bezel of this knob is loose. I can get my hand behind the dash, but I can't tighten my bezel by rotating it . What is the trick?
66 lemans ( with washer pin) Thanks Verstuurd vanaf mijn SM-G960F met Tapatalk
------------- Deurne, The Netherlands |
The lock nut is all that holds the Bezel.
Do you have the lock nut? If so the threads of the switch housing may be stripped.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:15 AM. |
Thanks Jef! Let me see if I can find something :-)
You'd have to look pretty hard for the set screw for that knob. It's probably better to just buy a new knob, which is available from our host. If you do find the set sccrew later, then you can put the original back on
The Following User Says Thank You to 66sprint6 For This Useful Post: | ||
