Parking brake adjustment
My pedal when released is only coming up about half way. If I pull the release out and use my toe it lifts up easy. Where is the adjustment for this?
Sent from my SM-G930V using Tapatalk
........I'm just learning as I go....... |
First make sure the rear brakes are adjusted correctly. If they are too loose the parking brake will be too loose also. If they are correct follow the cable back towards the rear and you will find a long threaded stud on the cable mechanism. Lube the threads liberally and tighten the nut. If it won't turn apply heat if available.
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
