Old 05-21-2020, 04:01 PM
Hanzel's Avatar
Hanzel Hanzel is offline
Default Bezel wiper knob
Hi guys, seems i lost my screw of my wiper knob. So I need to find one. But also the bezel of this knob is loose. I can get my hand behind the dash, but I can't tighten my bezel by rotating it . What is the trick?
66 lemans ( with washer pin)
Verstuurd vanaf mijn SM-G960F met Tapatalk
http://i62.tinypic.com/2mmagt3.jpg
Deurne, The Netherlands
Old 05-21-2020, 08:51 PM
Jeff Hamlin's Avatar
The lock nut is all that holds the Bezel.
Do you have the lock nut? If so the threads of the switch housing may be stripped.
Old 05-22-2020, 02:49 PM
Hanzel's Avatar
Thanks Jef! Let me see if I can find something :-)
Old 05-22-2020, 08:34 PM
You'd have to look pretty hard for the set screw for that knob. It's probably better to just buy a new knob, which is available from our host. If you do find the set sccrew later, then you can put the original back on
The Following User Says Thank You to 66sprint6 For This Useful Post:
