Old 02-18-2010, 10:19 PM
7072PMD's Avatar
7072PMD 7072PMD is offline
THAT'S WHAT I WAS LOOKING FOR, THANKS! I LIKE WHEN EVERYTHING IS FUNCTIONAL AND CORRECT. THE CAR IS A TIME CAPSULE!!
  #62
Old 02-18-2010, 10:48 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
like Lloyd was saying on that rear A/C bracket, Sonic made a run of reproductions and they did still have a number of them in stock about 3 months ago when I bought one. It's a very high quality piece, I think they were $175 or so when I got mine.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #63
Old 02-18-2010, 11:42 PM
2manyT/A'S's Avatar
Originally Posted by ccie3611 View Post
the survivor TA has a replacement alternator, however my other TA i'm restoring had the original alternator (that is i believe it is original) - see the pictures. of course as you can see it has been restored by a local shop, i'm not sure the fan should be black.
Fan & pulley should be silver zinc/cad plated
  #64
Old 02-19-2010, 12:41 AM
165th's Avatar
165th 165th is offline
Brent, great posts and pics. Congrat's on the find and thanks for posting up these pics.
Where is the shaker solenoid switch on your auto and 4spd? Are they both wired the same way?
  #65
Old 02-19-2010, 01:00 AM
2manyT/A'S's Avatar
Shaker switch on 72 T/A's was no longer on the carb.
The TH400 kickdown switch above gas pedal was used to activate shaker door,even on stick cars.
  #66
Old 02-19-2010, 03:35 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Brent, That is a spectacular find! Thanks for posting and many thanks for the invaluable pictures.
Jim
  #67
Old 02-19-2010, 09:36 AM
ccie3611 ccie3611 is offline
here are some pictures of the 4spd and auto kickdown switch
ID:	197779   Click image for larger version
ID:	197780   Click image for larger version
  #68
Old 02-19-2010, 09:50 AM
165th's Avatar
Thank you for those detailed pics on the shaker switch! You know I'd ask... what is that diode that can is wrapping over the switch on both cars? I'm familiar with the kickdown switch itself, but haven't seen the diode before.
Also, for the automatic car, does this mean the shaker door opens when the TH400 kicks down? Both happen at the same time?
  #69
Old 02-19-2010, 10:11 AM
not sure why the diode is there, it was on both cars so i'm sure its from the factory. not sure about the th400 kick down.
  #70
Old 02-19-2010, 12:23 PM
here's an interesting tid bit, notice how the hood stripe decal bends half way into the shaker opening lip - that would be very difficult to do.
  #71
Old 02-19-2010, 01:48 PM
Jim Rotella Jim Rotella is offline
That diode seems to be only on the '72 models. I think it's there because the '72 switch performs two tasks. It downshifts the transmission and it operates the hoodscoop door, and they do operate at the same time.
  #72
Old 02-19-2010, 01:55 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Question
That's what I was thinking as well, Jim.
I just checked my '72 SM, and the diode is not documented in the F-body wiring diagram though.
Regards,
"455HO" Lloyd
  #73
Old 02-19-2010, 03:02 PM
TA455HO's Avatar
TA455HO TA455HO is offline
A diode is like an electrical version of a check valve. Energy only flows one way through a diode. I wonder why they needed it?
Edit: I looked at the picture and my guess is that is a resistor, not a diode. Those are color bands if I'm not mistaken.
Diode
http://en.wikipedia.org/wiki/Diode
Resistor
http://en.wikipedia.org/wiki/Resistor
  #74
Old 02-19-2010, 03:38 PM
i was thinking the same thing - its a resistor
  #75
Old 02-19-2010, 04:43 PM
njsteve's Avatar
njsteve njsteve is offline
I believe the 1972 auto-equipped cars got the resistor'ed switch and the 4-speed cars did not. Since it was used to trigger two seperate electrical devices on an auto car, I think it was set up as a heavier duty model so it wouldnt burn out, working the 2 circuits at once.
  #76
Old 02-19-2010, 04:45 PM
njsteve's Avatar
This must be one of those IQ tests because I cannot get my brain to read what I'm looking at in the photo. Is it 2 people kissing...or an old lady and a young lady in the same image???
Can you uplink a wider angle shot?
  #77
Old 02-19-2010, 04:54 PM
Lloyd-TX's Avatar
I had to study that pic for a while myself, Steve. It's shot across the top of the hood, looking towards the passenger side. The blue background is what's so confusing - Brent's M22 T/A is parked next to this one.
Regards,
"455HO" Lloyd
  #78
Old 02-19-2010, 05:00 PM
the other photo is a closeup of the area circled in red
  #79
Old 02-19-2010, 06:09 PM
Lloyd-TX's Avatar
Rick - I thought that I remembered you were gonna buy one of those brackets from Barry.
Have you any idea yet if it's gonna fit properly?
Regards,
"455HO" Lloyd
  #80
Old 02-19-2010, 06:58 PM
njsteve's Avatar
LOL!
I can see it! I can see it!!!
(Thanks for humoring me)
