Old 10-04-2015, 08:21 PM
DanC's Avatar
DanC DanC is offline
Arrow Liquidating my 1st Gen Spare Parts
I am selling all my spare parts. They are used and in as removed condition unless otherwise stated. These are from a 28 year collection of parted cars mostly 1968. Prices do not include freight!
Please respond by Reply to Message so first come basis is established for all. No private messages for purchase.
Pictures available by request, but may take some time to do so as there are a ton of parts and there all in a cargo trailer at this point.
Now on to the list!........
Engine / Drivetrain
Intake Manifold 2bbl V8 $30
Carburetor 2bbl (1 serviceable, 1 parts) $40, $15
Carburetor Q-Jet (1 rebuildable, 1 parts) $75, $20
Misc Q-Jet parts $10
Timing Cover, V8 – ’68 $45
Push Rod Cover, V8 $20
Valve Covers & Breathers, chrome, new repro – $30
Air Cleaner Assy, V8 2bbl Nice! $45
Distributor Cap NIB Delco Remy $30
Distributor Hold Down Clamp & Bolt $5
Dipstick, Engine Oil, V8 A/C $5
Fuel Line, Fuel Pump to 2bbl Carb $5
Fuel Pump 2pc Eccentric, V8 $5
Crank Pulley Set 2pc, dbl groove and a/c V8 $30
Dipstick & Tube, AT – ST300 (2 speed) $15
Dipstick & Tube, AT – TH200-4R Chrome NIB Mr Gasket $25
Flexplate (“flywheel”), V8 AT $20
Axle Shafts, bolt in ’67-69 $50
Driveshaft w/ yoke, ’67 ‘400’ AT $100
Ring & Pinion w/ Open Carrier, 3.25 $100
Chassis
Trans Crossmember TH350, ST300 ’67-’69 $30
Trans Crossmember TH400 ’67-’69 $45
Steering Box, Power 2nd Gen $30
Four Piston Caliper LH & RH, need rebuild $150 pr
Rear Disc Brake (remd fr Cad Seville) Park Cables, Calipers, Mounts, 1 modified disc for mockup $100
Rally II Wheel set, 14x7 rust free, damage limited to trim ring scratches $120
Rally II Center Cap set, Red ‘PMD’ used orig $35
Rally II Trim Ring set, 14x6 nice used repro $40
Wheel Cover, Deluxe 14” blk centers $15
Body
Front Bumper Assy, complete (less grilles) used orig ‘400’ $300
Rear Bumper w/ four brackets used orig $200
T3 Headlight Bulbs used Hi or Lo beam small 4 light size $10 ea
Tail Light, good housing and trim, cracked lens ’67-68 $10
Windshield Wiper Linkage Assy, complete nice serviceable ’67-69 $45
Convertible Header Seal Kit 3pc w/ molded ends NIB (SoftSeal) $75
Trailer Hitch (dealer installed type) $20
Interior & Accessories
Seat Upholstery PUI, ’68-69 Standard, ’67 Deluxe Pearl Parchment 6pc set NIB $150
Door Panel Standard ’68-69 pair for trim parts only $20
Deluxe Door Parts ’67 only $20 for all
Air Cond inner/outer boxes, evap core and misc ducts, all for $200
Convertible Dash Speaker (Frame only) w/ dash mount $10
Instrument Panel Lens w/ Chrome Rings, new repro $20
Instrument Panel w/ printed circuit, Standard “Idiot Lights” ’68 $10
Steering Column, standard $25
Console Lid w/ hinge, '68 burlwood $20
Miscellaneous
Lots of small misc parts, inquire
Service Manual, repro 1968 VGC $30
Wiring Diagram, 1968 Firebird VGC $5
Misc Brochures and Magazine Advertisements, inquire
2nd Gen Parts
Air Cond Muffler, ’71 w/ service port $50
Steering Box, Power $30
Fisher Body Manual, 1971 orig VGC $25
Service Manual, 1971 orig GC $30
Misc 1969-72 GTO/LeMans
Defroster “Y” Duct, VGC, mount tab present 69-72 $35
Hood Scoops, orig diecast , good studs ’71-72 GTO $40 pr
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 10-05-2015, 07:16 AM
AG's Avatar
AG AG is offline
Can you send pics of the TH400 crossmember to:
ag8249@yahoo.com
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 10-05-2015, 07:58 AM
thebuick thebuick is offline
Default bumpers
interested in the front and rear 400 bumpers. pics to[ the67firebird@outlook.com] thank you
Old 10-05-2015, 08:30 AM
68tpls400 68tpls400 is offline
PM sent
Old 10-05-2015, 10:15 AM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
Do you have the muffler from the AC compressor available?
Old 10-05-2015, 08:36 PM
DanC's Avatar
Thumbs up Yes
I have the original '68 F muffler, lower in photo, but it has damaged tubes from an accident. The black one, upper in photo, fits and I had on my car but don't know what it came from and is not quite as the orig. The tubes run different.
My plan was to send both to Classic Auto Air and have them rebuild the original one. But things changed.
DanC
Name:	'68 AC Muffs.JPG
Old 10-06-2015, 12:01 AM
mrgto69's Avatar
Pypes Staff - Tech
DanC
Can you take a picture from the rear of the assy. I want to see how the tubes exit. I have a parts blow-up of the AC and just want to see how yours exits. Thanks
Old 10-06-2015, 06:40 PM
DanC's Avatar
Default Yep.......
more pics
Name:	FB AC Muff ends  (1).jpg
ID:	409764   Click image for larger version
Name:	FB AC Muff ends  (2).jpg
ID:	409765   Click image for larger version
Name:	FB AC Muff ends  (3).jpg
Old 10-06-2015, 09:47 PM
TROYBOYONE's Avatar
TROYBOYONE TROYBOYONE is offline
What year are the valve covers for?
Old 10-07-2015, 12:05 AM
mrgto69's Avatar
Pypes Staff - Tech
more pics
Thanks Dan
Old 10-07-2015, 08:03 AM
Hi, I am interested in the following:
1. Q Jet and parts. Do you have any part numbers?
2. Timing cover. 9790347? (if so, I will take)
3. Valve covers & breather. If stock style, I will take.
4. th400 crossmember
5. 14x6 rally II trim set. (rings, or caps?)
6. T3 headlights. I will take any that work
7. Trailer hitch
8. Console lid.
It would be great if you could send pictures. Email is Vike108@yahoo.com
Old 10-07-2015, 12:19 PM
mrgto69's Avatar
Pypes Staff - Tech
7. Trailer hitch
8. Console lid.
On the cross members... what model..? FB or GTO (hardtop or convertible)?
Old 10-07-2015, 12:26 PM
Everything is needed for stock '68 'bird.
Thank you.
Old 10-08-2015, 07:40 PM
DanC's Avatar
Red face Pics
I miss labeled the Valve Covers as repro. They are just aftermarket. But pics are attached in case you are still interested.
No bolts but there are 8 chrome mount tabs.
DanC
ID:	409906   Click image for larger version
Old 10-08-2015, 07:47 PM
DanC's Avatar
Default Firebird Parts
Firebird, coupes. "400" pic attached. Looks bad in photos but is not bad, just dirty and surface rust as removed way back. No scale, flakes, or pitting. Should clean up nice with a bead blaster.
DanC
ID:	409908   Click image for larger version
Old 10-09-2015, 08:46 AM
Dan,
Did you get my emails?
Old 10-09-2015, 10:27 AM
DanC's Avatar
Post
Dan,
Yes, and I've sent three emails with pics yesterday and two days prior to your provided email addy.
DanC
Old 10-09-2015, 11:23 AM
DanC
I received two emails yesterday with pictures, and I responded back to both emails.
Here are the items I will take:
1. Valve cover and breather set
2. Trailer hitch
3. Rally II trim ring set. (do you know where you got that so I can maybe match them up?)
4. T3 headlights (if they work)
5. Console lid '68
6. TH400 cross member
And let me know what numbers are stamped on the Q jets.
I'm not sure what the issue is with the emails.
Old 10-10-2015, 10:49 PM
67topless 67topless is offline
Default 67 Firebird Parts
Dan:
Interested in:
68 timing cover
67 deluxe door parts
68 steering column floor shift
Also need a 67 Firebird door glass (driver side)
Please send pics.
Old 10-12-2015, 07:08 PM
DanC's Avatar
Exclamation These six items pending sale:
2. Trailer hitch
4. T3 headlights
5. Console lid '68
Verbal sale on the above items!
DanC
