Old 12-13-2016, 02:35 PM
Judge273's Avatar
Judge273 Judge273 is offline
Thanks guys!
Getting the missing parts from good sources that do great work is fun too...
Got a lead from James on this evap on eBay. Factory auto air knocked it out of park!
Mike/Illinois
  #82
Old 12-13-2016, 04:24 PM
RamAir's Avatar
RamAir RamAir is offline
[QUOTE=Judge273;5668527]Thanks guys!
Jewelry
  #83
Old 12-13-2016, 07:03 PM
weranc55's Avatar
weranc55 weranc55 is offline
Thanks guys!
Very nice
  #84
Old 12-13-2016, 07:24 PM
Judge273's Avatar
Set it up poa valve for 134A too.
Mike/Illinois
  #85
Old 12-13-2016, 07:27 PM
njsteve's Avatar
njsteve njsteve is offline
Very nice: it has the original expansion valve with the short capillary tubes instead of the coiled up, one-size-fits all replacement part.
  #86
Old 12-13-2016, 07:35 PM
Judge273's Avatar
More pix..
Should keep the girl cool in summer!
Mike/Illinois
  #87
Old 12-13-2016, 07:47 PM
RamAir's Avatar
A happy wife is a happy life
  #88
Old 12-13-2016, 07:49 PM
Judge273's Avatar
So, who can give me some assembly tips?
1. After the body gets painted...should I put stripes on?
2. Put rear and sub on with body shop so they can align panels.
3. Take body home and do the assembly? Rear, sub, drop in drivetrain?
Anyone with advice, it is much appreciated!
Mike/Illinois
  #89
Old 12-13-2016, 08:32 PM
SD455DJ SD455DJ is offline
Dang Mike! You're really going to town on this car. I think you are going to be driving it by spring at this pace. Looking great too, especially the AC box assembly. I need to get my AC on the Bird going this year as well.
If you need any parts, check with woogie0004 in the Parts For Sale section (I think you bought some seat belts from him recently) as he has almost everything for the second gens. Merry Christmas!
Dennis
  #90
Old 12-13-2016, 08:37 PM
Judge273's Avatar
Thanks Dennis,
I did buy a full set of seat belts from Adam, and a dryer with hose too.
Thanks for the support on this project. But, I'm a bit over my head.
Spending a hour a day towards the cause.
Learning it from this board.
Mike/Illinois
  #91
Old 12-13-2016, 09:34 PM
weranc55's Avatar
He's probable going to need the sub frame in order to lineup the front end before he paints.
I've put in the drivetrain after the car has been painted and the front clip on for a non ac car. For a ac car if you could got the car painted with the front end off and then put you drivetrain in and take it back to get the clip bolted on. Makes life easier.
  #92
Old 12-13-2016, 10:16 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Default The right sequence matters
Most body/painters like to mock fit everything prior to paint so they can see the fit. determine how many shims, etc. He will need the subframe and all sheetmetal, spoilers, etc to make sure they fit right prior to paint. he may want to add or take away on some of the skim coats to eliminate or make the gaps even.
You don't wont to find out it doesn't fit well and needs more work after its painted.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #93
Old 12-14-2016, 06:54 AM
Judge273's Avatar
Now, what if they dry fit the body, bumper, trunk lid, spoilers, doors.and get it all painted.
I take it back to hang firewall stuff, install subframe, rear and bring back for front end alignment of shim, washers, fitment?
Kinda of like Chuck said..
Would that work or create more potential work?
Just not sure what would need to be adjusted past doors?
Just a thought?
Mike/Illinois
  #94
Old 12-14-2016, 07:43 AM
Norwood's Avatar
Norwood Norwood is offline
I would ask the body guy how he wants to do it. He is the guy who's doing it, right ?
  #95
Old 12-14-2016, 09:15 AM
Judge273's Avatar
He said he's flexible. That's why I'm asking the question here.
Like to get thoughts and make an educated decision.
Is it the fender/door gap that is the big concern? Not sure where else the shims and washers come into play.
Mike/Illinois
  #96
Old 12-14-2016, 09:24 AM
Norwood's Avatar
I would hope that the guy doing it would be the most. "educated " in the work that he is doing. But what do I know
  #97
Old 12-14-2016, 09:40 AM
Judge273's Avatar
I'll defer back to him as I'm flexible.
Never did a fbody before and many here have.
Looked at keepat thread and looks Ike he had the subframe on and off many times...trying to min the process.
Mike/Illinois
  #98
Old 12-14-2016, 10:19 AM
weranc55's Avatar
Agree. Everybody likes to do something different but he has to have the front end aligned on the car before he paints it. If not you could have poor gaps.
  #99
Old 12-14-2016, 11:13 AM
Judge273's Avatar
Sounds like good advice too and will save the back n forth too. I'll get them the subframe and rear. Let them attach.
Then, the engine drivetrain with firewall stuff will follow before final panel and hood reattaching.
Car will comeback all intact ready for interior install. Best plan of attack.
Mike/Illinois
  #100
Old 12-14-2016, 03:22 PM
1971455HO's Avatar
Just a suggestion...
Talk to your body man, he's not a novice. You're paying him, let him know your concerns. You and him can get a game plan. I'm probably out of sync with how you are doing this. There's many ways to get there. I'm sure he has his.
I had assumed you took the whole car to the body/painter to have him finish up on all the finer points of prepping this car for paint. That way he fits everything so he knows its right prior to paint. After that, the sub can be removed to strip down, clean and paint, assemble new suspension parts, steering,etc. After paint (I'm skipping some steps here) the body and all sheetmetal will get wet sanded and buffed prior to assembly. Install engine harness and other associated hardware onto the firewall. When all is ready to assemble install engine & trans on the completed ready to install subframe and mate with the body as one unit. So much easier.
Tip: Be sure to bring the hood hinges you intend to use. No two sets of hinges operate exactly the same. I strongly recommend you source a good pair if yours are excessively worn. I've dealt with that. Also take care of any weak or broken rear deck lid springs prior to paint. You don't wont to mess with that after its all pretty and shiny. Do you or the body man have experience with installing these type of stripes and decals????
It's important!
Ol' man Smith
Son video'd this...
