70 A/C vacuum connections
working on the A/C evap. box . these three lines of course come from dash control. is one of them for a vac. canister .
could someone post a pic of what it looks like . I looked in assembly manual and nothing in there Thanks Don |
The picture of the canister mounted to the firewall was taken of a 1970 Formula 400, four speed, a/c car.
could you share the color code of where the lines go . looks like clear, blk, red plenum door color vac tank color heater control valve color |
That car is long gone, so I can't check the routing for you. I'm not sure what year you're working on, but this picture was taken from the 1970 F body supplemental shop manual.
It looks like black is your vacuum source, maroon is to the hot water valve, and the gray is to the purge diaphragm. |
It looks like that vacuum check valve in the black (source) vacuum hose is available from Ames Performance Engineering, part number FP341B ($12.00).
From the pic in post 2 the vacuum motor has two ports used . Mine (as pic shows) only has one open .
yes my car is a 70 |
But in the diagram post . it looks to show vac motor to not use that port .
Diagram also shows NO vacuum. tank . I don't recall the vac tank on my car . so that makes sense |
( Refer to post #2 above ) The black "Vac tank" on the firewall has nothing to do with AC directly. It gets hooked to the choke pull off on the Q-jet. It is only on a formula 400, NON Ram air cars, that I have seen. I have NOT seen them on a factory 2bbl 400 either.
I found it in catalog . Thanks for your help. Don |
Just reading this thread now. Not sure if you need any additional images, but my '70 T/A is an A/C car.
Car was fully restored when I got it, so I probably can't answer any assembly questions but am more than will to get you pics of whatever you need. Mike |
Don |
OK, I posted one from the under hood but got a message it was waiting for admin approval before it will post.
Once that happens it should show up |
never heard of that . didn't have a MAGA sticker on firewall did it ..LOL
I posted some images yesterday in the "WTB Cars" thread since I got the car I had been looking for and got the same message then as well.
Maybe because I have a low post count being new? |
should be all set in a few days usually
