Old 07-17-2020, 07:17 PM
cnc's Avatar
cnc cnc is offline
Default Rear spoiler torsion bars for trunk
Has anyone used the reproduction torsion bars for the trunk lid with spoiler ....I’m adding rear spoiler and want correct torsion rods ...thanks for any input ...Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 07-17-2020, 09:08 PM
Formulabruce's Avatar
I have used them and they are a bit stronger than stock. You only need the 1 thicker rod that works the pass side
Hinge.
Old 07-17-2020, 10:17 PM
cnc's Avatar
cnc cnc is offline
Hey Bruce thanks,,,, so just the pass side to change out cool...
Old 09-07-2020, 01:02 PM
cnc's Avatar
cnc cnc is offline
Which is really the drivers side with the adjusting and release position ..just like this video for the rod to be changed out.....right ???
Found this video on YouTube best tool I've seen so far
https://m.youtube.com/watch?v=2i9hfKe8HLA
Old 09-07-2020, 03:17 PM
While the "drive pin" and pressure rest against your nice quarter ..
The one being done in the video IS the hard one, the pass side, which locks into the DS as my video shows.
Doing this before paint is highly recommended .
One can put in a strut as well, which works very well, especially with a remote electric trunk release, which
keeps the keys away from the tail panel.
Old 09-10-2020, 04:58 PM
Formula8's Avatar
Formula8 Formula8 is offline
I just replaced one side with the aftermarket replacement. PITA but works fine.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 09-11-2020, 12:27 PM
cnc's Avatar
cnc cnc is offline
Who did u get it from just curious????
Old 09-11-2020, 01:36 PM
Formula8's Avatar
Classic Industries. It was over 10 years ago.
Old 09-13-2020, 08:42 PM
cnc's Avatar
cnc cnc is offline
https://www.classicindustries.com/pr...s/9868540.html
https://www.classicindustries.com/pr...s/9868539.html
So which one ????
Confused on which to order going by there description
Old 09-14-2020, 10:47 PM
So which one ????
While shown backwards in the pic, This is the correct one.
It MUST be thicker than the other one/. I believe Ames has these as well.
Old 09-15-2020, 06:25 AM
cnc's Avatar
cnc cnc is offline
Ok got it thanks Bruce appreciate the clarification....
Old 09-25-2020, 10:51 PM
cnc's Avatar
cnc cnc is offline
Ordered the 540 Got it installed made a tool Iike the video but still a BEOTCH TO GET IN but it's done...now for the spoiler install..
Old 09-27-2020, 05:14 PM
Formula8's Avatar
Glad to hear that it worked out. I installed my spoiler by taking out the studs and putting small balls of clay in the stud holes. I simply stuck the spoiler exactly where I wanted it then when you pull off the spoiler, the clay balls stick to your trunk lid showing you exactly where to drill. Replace the studs and you are good to go.
Old 09-28-2020, 07:15 AM
cnc's Avatar
cnc cnc is offline
That is exactly what I plan on doing ....👍
Old 09-28-2020, 07:05 PM
fbd73's Avatar
fbd73 fbd73 is offline
I have just ordered a torsion spring set for my '73. It already has a spoiler on in and the boot lid continuously falls down when open. I hope it isn't too had to fit.
Old 09-28-2020, 07:59 PM
cnc's Avatar
cnc cnc is offline
Make the tool like the video...hardest part for mine was getting the torsion rod behind the hinge area the tool give u a lot of leverage ...
Old 09-28-2020, 08:09 PM
fbd73's Avatar
Damn. I should have done it before the car came out of the paintshop.
Old 09-29-2020, 07:19 PM
cnc's Avatar
cnc cnc is offline
Yes ......if u make the tool and cover the quarter and have some help u might be ok OR like Bruce has mentioned a strut could be installed as well never seen one so I can't comment on fit..maybe Bruce will chime in
