Old 08-06-2020, 03:02 PM
dld's Avatar
dld dld is offline
Default 70 A/C vacuum connections
working on the A/C evap. box . these three lines of course come from dash control. is one of them for a vac. canister .
could someone post a pic of what it looks like . I looked in assembly manual and nothing in there
Thanks Don
ID:	546549   Click image for larger version
Old 08-06-2020, 04:45 PM
The picture of the canister mounted to the firewall was taken of a 1970 Formula 400, four speed, a/c car.
ID:	546551   Click image for larger version
Old 08-06-2020, 05:09 PM
dld's Avatar
dld dld is offline
excellent big help!
could you share the color code of where the lines go . looks like clear, blk, red
plenum door color
vac tank color
heater control valve color
Old 08-06-2020, 05:28 PM
That car is long gone, so I can't check the routing for you. I'm not sure what year you're working on, but this picture was taken from the 1970 F body supplemental shop manual.
It looks like black is your vacuum source, maroon is to the hot water valve, and the gray is to the purge diaphragm.
Originally Posted by dld View Post
excellent big help!
plenum door color
vac tank color
Old 08-06-2020, 05:43 PM
dld's Avatar
dld dld is offline
THANKS that helps
Old 08-06-2020, 06:08 PM
It looks like that vacuum check valve in the black (source) vacuum hose is available from Ames Performance Engineering, part number FP341B ($12.00).
Old 08-06-2020, 06:34 PM
dld's Avatar
dld dld is offline
From the pic in post 2 the vacuum motor has two ports used . Mine (as pic shows) only has one open .
yes my car is a 70
Old 08-06-2020, 06:40 PM
dld's Avatar
dld dld is offline
But in the diagram post . it looks to show vac motor to not use that port .
Diagram also shows NO vacuum. tank . I don't recall the vac tank on my car . so that makes sense
Old 08-06-2020, 09:30 PM
Formulabruce's Avatar
( Refer to post #2 above ) The black "Vac tank" on the firewall has nothing to do with AC directly. It gets hooked to the choke pull off on the Q-jet. It is only on a formula 400, NON Ram air cars, that I have seen. I have NOT seen them on a factory 2bbl 400 either.
Old 08-07-2020, 11:52 AM
dld's Avatar
dld dld is offline
I found it in catalog .
Thanks for your help. Don
Old 09-16-2020, 06:52 PM
MMunger MMunger is offline
Just reading this thread now. Not sure if you need any additional images, but my '70 T/A is an A/C car.
Car was fully restored when I got it, so I probably can't answer any assembly questions but am more than will to get you pics of whatever you need.
Mike
Old 09-17-2020, 11:59 AM
dld's Avatar
dld dld is offline
Mike
Thank you , everyone likes to see pics of our cars . post a pic of engine and A/C area . Would lov to see it
Don
Old 09-17-2020, 12:57 PM
Hows this?
Old 09-17-2020, 02:26 PM
OK, I posted one from the under hood but got a message it was waiting for admin approval before it will post.
Once that happens it should show up
Old 09-17-2020, 02:35 PM
dld's Avatar
dld dld is offline
never heard of that . didn't have a MAGA sticker on firewall did it ..LOL
Old 09-17-2020, 03:22 PM
I posted some images yesterday in the "WTB Cars" thread since I got the car I had been looking for and got the same message then as well.
Maybe because I have a low post count being new?
Old 09-17-2020, 08:20 PM
should be all set in a few days usually
