Tri-Power Tech 57-66 Tri-Power Talk
Old 08-20-2020, 05:33 PM
lucky1 lucky1 is offline
Default 1966 tri power choke pull off
Could a faulty pull off cause restarting as well.
Thanks in advance.
Old 08-20-2020, 09:04 PM
Tom Vaught's Avatar
Boost Engineer
Explain "restarting" please.
Tom V.
Old 08-20-2020, 09:25 PM
Default Choke pull off
Engine is at operating temperature and switched off. Hard to start five minutes later. Thanks.
Old 08-21-2020, 04:30 AM
Kenth's Avatar
Kenth Kenth is offline
The choke pull-off is only used to open choke blade some at cold start.
With hot engine, no choke, no choke pull-off.
Using a mech fuel pump (with check valve) and fuel line close to hot engine parts fuel pressure rises to a point where inlet needles leaks and raw fuel dribbles down into intake making hot starts after 5-30 minutes hard.
Fuel filter with return line to the tank or/and usage of an electric fuel pump mounted close to the tank bypassing the mech pump eliminates the issue.
Hope this helps some.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-21-2020, 12:58 PM
Tom Vaught's Avatar
Boost Engineer
X2 on post by Kenth now that I understand your carb issue.
I had special heat insulators under my Rochester Tri-power Carbs for many years in the 1960s. Helped in the Missouri summers.
Tom V.
Old 08-21-2020, 06:16 PM
carbking's Avatar
carbking carbking is offline
Check this link:
http://www.thecarburetorshop.com/Tro...m#Hardstarthot
Jon
