Looking for all door seals and trunk seal
I also have this in the wanted section but...I’m looking for some replacement seals for my 73
Need door trunk etc.....lmk what u guys have used with good results ...thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
When I replaced that seals on my 67 Firebird I got them through Classic Industries.
67 Firebird Convertible |
Hi were they OER
Also see Metro has a kit 5 piece both doors and trunk for like $206 then on eBay same kit from another seller half the price made by metro....
I used a set of Fairchild door seals recently. Very nice product, doors closed like factory. I Highly recommend them based on my experience. https://www.jegs.com/webapp/wcs/stor...ild+Automotive
The Following User Says Thank You to Norwood For This Useful Post: | ||
I will have a NOS trunk seal available in a couple of days if you want to go that route.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Always the best route, if you can afford it.
77Canamman pm sent...
The Following User Says Thank You to cnc For This Useful Post: | ||
https://www.carid.com/fairchild/roof-weatherstrips.html
I only can vouch that the door seals are very good. I have good GM window seals
Ok thanks ...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 08-28-2020 at 08:46 PM. |
Now for the roof rail/window seals....
See these on eBay
https://www.ebay.com/itm/1970-81-GM-....c100667.m2042
I used their belt/window seals on my 1973 Formula 455 with the large stainless trim on the belt line. They fit well.
I actually have aset of Fairchild sweep with the chrome trim...I bought them from4004 speed I was going to remove the decor trim from the car but have now decided against it....so I will selll these and go back to the original style for replacement ...I need all 4 pieces for the doors inner and outer....
https://www.steelerubber.com/cart Parts place I assume??? https://www.ebay.com/itm/1970-81-GM-....c100667.m2042
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 08-29-2020 at 12:31 PM. |
Based on 4 cut cross sections of Trunk seals and fit, I have found that the 1A auto trunk seal lays down in the gutter the best and seals properly. These are better fitting than what GM was selling in 1982. In Video you can see how well this conforms to the trunk channel/ gutter.
https://www.1aauto.com/1970-81-chevr...36/258266/1973 video here > https://www.youtube.com/watch?time_c...ature=emb_logo |
Bruce u r happy with them then .....good to hear.
It’s over $83 US plus any border stuff to get it here....not gonna happen.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 08-30-2020 at 07:00 PM. |
Thread Tools | |
Display Modes | |
