Old 08-02-2019, 04:14 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Pro's....and con's...
Looking at a brake line kit....for my bird......and undecided on stainless....or carbon steel....
Any input is appreciated...
Old 08-02-2019, 04:47 PM
indymanjoe's Avatar
stainless is not stainproof. Also a pain to work with. I went with steel. Will never see salt.so far some water as a driver has been fine for 5yrs so far.
These cars are meant to be driven, so enjoy the hell out of all of it - not just look at it when it's clean.
Old 08-02-2019, 05:57 PM
Gator67's Avatar
Gator67 Gator67 is offline
if you'll be bending and flaring lines yourself, nicopp/cunifer is a good option
Old 08-02-2019, 06:53 PM
JLMounce JLMounce is offline
Any reason you aren't considering a pre-bent kit? Even if you have non-factory equipment on the car, starting with a pre-bent kit will typically get you 90% of the way there. It's what I've done on my own bird. Always started with the factory lines, then modified as needed.
-Jason
1969 Pontiac Firebird
Old 08-02-2019, 06:57 PM
Thought I mentioned KIT...in my original post?
Old 08-02-2019, 07:24 PM
NiCopp as mentioned,
Old 08-02-2019, 08:28 PM
Gator67's Avatar
Yup, you said kit. But there are universal kits consisting of lines, fittings, etc., as well as pre-formed/bent kits.
Old 08-02-2019, 09:33 PM
My car is stock.....so the pre-bent kit....is what I am considering.....
Old 08-10-2019, 10:48 PM
Bandit400 Bandit400 is offline
I went with stainless steel and I love it. Unless you will be cutting/flaring them, you'll never run into any issues, and mine are 10 years old, and still look brand new. You may need to tighten/loosen them twice when attaching the brake hardware to ensure a good seal, but I'd do it again in a heartbeat.
Old 08-11-2019, 11:59 AM
This ^^^ And your fittings won't leak unless you cross-thread them.
Old 08-12-2019, 05:11 AM
Geoff Geoff is offline
Also agree.
Original threaded fitting size was never designed to be used with s/s, which is a harder metal; it requires more tightening torque to compress the flare for a good seal. Which could result in stripped threads, twisted threads or broken fittings.
