Old 07-26-2019, 07:05 PM
SD455DJ SD455DJ is offline
Yes, that is correct Stuart. They have 2 isolated paint booths from the main shop.
Here are a few more progress pics from Dan showing all the glass installed, the interior door/quarter panels & window cranks installed, and the side body moldings installed. The Verdoro paint sure looks pretty out in the sun!
Dennis
ID:	516547   Click image for larger version
ID:	516548   Click image for larger version
ID:	516549   Click image for larger version
ID:	516550   Click image for larger version
  #202
Old 07-31-2019, 05:31 PM
The original shifter porch is in the Cat...wiring going in next then the dash/gauges/heating controls, and carpet.
Dennis
  #203
Old 08-13-2019, 07:59 AM
rustyrelic rustyrelic is offline
Default show us more
Come on already! The suspense is killing me here. Need more progress pics.
  #204
Old 08-13-2019, 09:27 AM
I'll be visiting this afternoon and will see if Dan has made more progress on the Cat. He had all the interior and under dash wiring cleaned up and ready for reinstallation...not really exciting stuff and time consuming.
Dennis
  #205
Old 10-07-2019, 04:19 PM
There was a little more progress on the Cat...the trunk lid and rear valance panel (not installed yet). Front end coming soon....
Dennis
ID:	521735   Click image for larger version
  #206
Old 10-07-2019, 05:44 PM
muscle_collector's Avatar
loving that car
  #207
Old 01-19-2020, 05:25 PM
Dan and I installed the restored dash and gauges. All the controls and wiring hook-ups are next along with the padded dash top.
Dennis
ID:	529174   Click image for larger version
ID:	529176   Click image for larger version
ID:	529178   Click image for larger version
ID:	529179   Click image for larger version
  #208
Old 01-19-2020, 06:41 PM
Stuart's Avatar
Stuart Stuart is offline
Looks great!
  #209
Old 01-19-2020, 08:20 PM
coonhunter70 coonhunter70 is offline
Can't wait to see it finished
  #210
Old 01-19-2020, 11:37 PM
trophy421 trophy421 is offline
Looking fantastic!!! That car is cool beyond belief.
  #211
Old 02-04-2020, 08:05 AM
It's kind of hard to show the progress because its a bunch of the little things that need to be routed, connected, and fooled with under the dash (wiring and hvac controls), blower motor, speedo cable, etc.. Dan installed the rebuilt wiper motor and re-restored the steering box. The pulleys are on the 428 now and getting close to attaching the M-21 tranny and sliding them in.
Dennis
ID:	531075   Click image for larger version
ID:	531076   Click image for larger version
ID:	531077   Click image for larger version
  #212
Old 02-05-2020, 01:15 PM
1_Wild_Cat's Avatar
Incredible car and great work on the resto. Simply beautiful work and attention to detail.
  #213
Old 02-05-2020, 01:51 PM
Thanks 1_Wild_Cat. Dan gets all the credit there in the resto department...I just get to help every once in a while and post the progress for him.
Dennis
  #214
Old 02-05-2020, 06:16 PM
Dan started the install of the 428 HO motor this afternoon...getting fun now! The 428 HO dyno'd at 432 hp @ 5000 rpm and 502 lbft torque @ 3700 rpm with a real 068 cam and a true 10.75 to 1 compression through inferior flowing A-body RA manifolds with 2 1/4" outlets. The M-21 and shifter/linkage are going together next...
Dennis
ID:	531154   Click image for larger version
ID:	531155   Click image for larger version
ID:	531156   Click image for larger version
  #215
Old 02-05-2020, 07:41 PM
Stuart's Avatar
It's getting close... Any chance of sourcing the correct big car exhaust manifolds?
  #216
Old 02-06-2020, 05:57 AM
gtospieg gtospieg is offline
Are those F body manifolds?
  #217
Old 02-06-2020, 07:55 AM
Sorry!...Failed to mention that the engine with the long branches wouldn't fit on the dyno, so Dan had to use the later type A/F-body RA manifolds. The original long branch manifolds are back on the engine that you can see in the passenger side picture.
Dennis
  #218
Old 02-06-2020, 08:34 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks fantastic and great numbers on the 428, should be real fun w a 4spd.
Chris D
  #219
Old 02-07-2020, 11:38 AM
mr67gp mr67gp is offline
Fantastic. What heads did you use? 10.75:1 and iron heads = not pump gas friendly, I would imagine?
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
  #220
Old 02-07-2020, 01:54 PM
We need to find factory 67-68 B-body 4-speed linkage rods and levers. Dan has the shifter and mounting plate, but only has the Hurst Competition Plus aftermarket rods and levers, which are different than the factory pieces. The factory rods are bent to stay lower and away from the tunnel (vs. the A-body rods that run higher). I attached the illustrations for the 68 assembly manual to show the differences.
Anyone know the whereabouts of these??? We'd buy a complete 4-speed setup if necessary.
Thanks OCMDGTO and mr67gp for the comments. The engine is running its original #16 heads (no mods) and it won't be pump gas friendly. It won't be driven that much on the street, so tanking up with 1/2 race gas from time to time won't be an issue.
Dennis
Name:	68 B-Body 4-spd Linkage1.jpg
ID:	531349   Click image for larger version
Name:	68 A-Body 4-spd Linkage1.jpg
