Old 09-05-2018, 07:50 PM
Jshiel50's Avatar
Jshiel50 Jshiel50 is offline
Default 1971 GTO 400 4speed survivor FOR SALE
Unmolested 1971 GTO 400 4speed 3.90 rear. 48,388mi on the odometer. Numbers matching motor (Carb to Pan.....even the alternator) have all vehicle history and previous owner contact info and copies of the dealer advertisement the week it was sold 4/8/1971. Cragars and kelly bias plys were put on a month after the car was purchased and will stay with the car. Currently on a set of rally's. About as original as it gets. Located in Virginia. $34,000. Contact me for more information. Joe- 571.921.5044
Sent from my SM-G930V using Tapatalk
Old 09-06-2018, 06:32 AM
Judge273's Avatar
Judge273 Judge273 is offline
Would you mind posting the phs?
Mike/Illinois
Old 09-07-2018, 08:36 PM
Jshiel50's Avatar
PHS is ordered and on its way. I will post PHS when the docs arrive. More pics will be posted of identification numbers for block, carb etc and more of the car's condition also.
Old 09-14-2018, 07:43 PM
Jshiel50's Avatar
PHS will be posted on Monday
Old 09-14-2018, 09:28 PM
unruhjonny's Avatar
That is super cool!!
GLWS!!
1970 Formula 400
Old 09-15-2018, 07:40 AM
Judge273's Avatar
The reason I asked to see the phs...
The 400/4 speed with a 3:90 axle ratio was a 10 bolt posi unit (XPP)
It was standard axle on a L78 with a M22.
Special order on a L78 with a M20.
PHS will show how this was originally equipped.
Mike/Illinois
Old 09-15-2018, 07:44 AM
The Boss's Avatar
The Boss The Boss is offline
And go racin' in the street.
Old 09-17-2018, 02:10 PM
Jshiel50's Avatar
First round of phs docs received over email today.Click image for larger version
ID:	492940Click image for larger version
Name:	71 GTO(2).jpg
ID:	492941Click image for larger version
Name:	71 COLORS.jpeg
Old 09-17-2018, 04:56 PM
1969 Ram Air 1969 Ram Air is offline
Looks like M20 and 3.55....right?
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 09-17-2018, 05:33 PM
Jshiel50's Avatar
I will check the rear end tag again when i get back to the house. If that doesn't tell me then ill have to wait for the build sheet to post that. Original owner remembered the car having 3.90 rear gears.
Old 09-17-2018, 05:56 PM
unruhjonny's Avatar
I would think that the PHS would show a 'performance alxe' option if you had non-standard gearing;
It does appear as though your foctory installed gearing is 3.55:1 - did the owner maybe say something along the lines of "the car has 3.90:1 gears" as opposed to "the car was ordered with 3.90:1 gears"?
1970 Formula 400
Old 09-17-2018, 06:12 PM
Judge273's Avatar
PHS would show a (35G) M22 to automatically getting the 3.90 axle.
The Muncie case will also be stamped with correct code and date if it has matching VIN.
Axle code will also be stamped on axle (XPP) for 3.90 or (XHP) for 3.55 both 10 bolt rears.
Based on PHS it's a M20 (35E) and 3.55...
Special order axle not on PHS to be 3.90 either.
Mike/Illinois
Old 09-17-2018, 06:26 PM
Jshiel50's Avatar
Original owner bought the car off the show room floor while looking for a used hemi car at the time. You all are a wealth of knowledge and all i can go off of right now are date codes and interviews i had with the orginal owner.
Old 09-17-2018, 06:32 PM
Jshiel50's Avatar
Would the stamping be on the pumpkin or the axle tubes?
Old 09-17-2018, 06:59 PM
Judge273's Avatar
Here is mine on my 71 with a 12 bolt posi stamped on axle tube and Julian date.
Mike/Illinois
Old 09-17-2018, 07:15 PM
What trans is the 35E code?
Old 09-17-2018, 07:24 PM
Judge273's Avatar
35E is M20
Mike/Illinois
Old 09-29-2018, 05:19 PM
Jshiel50's Avatar
Correction to the sale post.....(and thank you for the guidance) upon finally having a chance to inspect further the rear axle tube is stamped p341 XH. So it is a 3.55 rear gear car.
Old 09-29-2018, 05:21 PM
Jshiel50's Avatar
Also copies of the original sales ads before the car was sold on 4-8-1971
Old 09-29-2018, 11:18 PM
unruhjonny's Avatar
I'd love to read those;
Do you have a link to larger pictures?
1970 Formula 400
