Old 04-03-2019, 11:45 PM
Default newer engine for 1955 Chieftain
What is the newest engine that will bolt to a 1955 Hydramatic trans? Will the 1958 370 fit? Will the 347 or 370 bolt up with no modifications or is something else needed?
Old 04-04-2019, 01:11 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
All engines up through '60 will bolt to the '55 HydraMatic. '59 & '60 just need a small amount removed from the back of the crank flange to clear the early HydraMatic flywheel.
Old 04-04-2019, 09:04 AM
Bill Hanlon's Avatar
There is more detail to be had here http://www.pontiacsafari.com/L1Garag...eID/index.html
Scroll down to "Interchangeability".
Old 04-04-2019, 11:22 PM
Thanks a lot. That website is very good.
Old 04-05-2019, 12:59 AM
Yes, the PontiacSafari website is good. But it only says that "later" engines had the flywheel flange weights. As I said above, those weights didn't appear until the 389 (1959). The DualRange flywheel will bolt directly to all '55-58 cranks. Also- if the '59-60 flywheel flange is machined just enough to clear the early flywheel, there's no need to re-balance the crank.
