Old 06-27-2019, 02:01 PM
not a charger not a charger is offline
Default Husrt shifter ID? OEM?
I have an extra shifter that came with my 78 W72. It has 2 patent numbers on it - 3216274 and 3306126. From what I can tell, those mean that it's a Competition Plus shifter. The only other number on it is on the same side as the patents, but toward the front of the shifter. That number is 0483091 B. On the opposite side, it says "Made in Canada." The shift handle looks identical to the one in my W72. I'm going to sell it, and I want to make sure I know what the heck it is when I advertise it. I don't want anyone to buy the wrong thing. Can anyone clue me in as to what this is?
ID:	514942   Click image for larger version
ID:	514943   Click image for larger version
Old 06-27-2019, 02:35 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The factory 81 Camaro shifter I have looks like a Hurst but is an ITW or ITC, forgot which.
Skip Fix
Old 06-27-2019, 04:54 PM
unruhjonny's Avatar
I made a similar post recently looking for this information HERE - I never got a reply.
It was suggested that I buy a book...
By looking at info from the book's author, it appears as though aftermarket Hurst shifters use the stamped case number as the serial number
I was hoping ot somehow identify the date of the shifter by a stamping on the shifter body.
You can positively ID a factory versus an aftermarket Hurst by the absence or presence of positive stops, and provisions for a bolt on shifter handle - both of which yours doesn't have.
1970 Formula 400
Old 06-27-2019, 05:22 PM
Awesome info. Thank you so much.
Old 06-27-2019, 06:29 PM
unruhjonny's Avatar
I'm happy I could be of help!
1970 Formula 400
Old 06-27-2019, 09:42 PM
Held for Ransom's Avatar
Look for numbers stamped on the rods. Shifter looks OE. What is the number stamped on the handle? No number stamped on the side of the shifter body?
So long, farewell.
Old 06-27-2019, 10:06 PM
Shifter is gone. I had an ad on Craigslist for a shaker and air cleaner, and the guy showed up to buy it, and bought almost everything else I had.
Thank you again to everyone for helping. This board is awesome.
