Old 07-18-2019, 01:18 AM
PepinoBBB PepinoBBB is offline
Default 64 rear window channels
Hi Guys By any chance any body knows if the rear window channels for 64 are the same for 65/66/67. ? thanks
Old 07-18-2019, 06:33 AM
Cardo's Avatar
Cardo Cardo is offline
65 should be the same....i don't think 66 or 7 will work. The Buick and Olds will probably work too.
"I know just enough to keep me here, but not enough to get me out"
Old 07-18-2019, 03:54 PM
Dick Boneske's Avatar
If you're talking about sedans, the '65 is slightly different from the '64 in the way it's attached to the rear inner fender well. When doing my '64 sedan, I found the weatherstip inside to be unavailable. I tried a generic liner, but it would not work---the bottom of the channel was too thick and the window would not roll up.
I spent at least two weeks on those rear windows.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-18-2019, 07:54 PM
LATECH's Avatar
LATECH LATECH is offline
are you talking about the rear quarter windows?
Is your car a post or hardtop?
Old 07-18-2019, 08:01 PM
LATECH's Avatar
These sure look like the ones in my 64 GTO
I bought the channel material and replaced that onto the OE metal guide piece on my car.
These ( Below)look like they have recently come out.
https://www.google.com/search?q=1964...aze24Eg1314KM:
Also the vertical channel was not at all easy to find,( and I assume is not available), as it is a guide for the window.
I was able to get a felt (fuzzy) pile weatherstripping that I used adhesive to attach. I couldnt find black, so I colored it with a permanent sharpie.
It was something like .187 wide ( 3/16) by .250 thick
Old 07-18-2019, 08:08 PM
My car is a SW
Old 07-24-2019, 12:57 PM
tempest1964's Avatar
Does that make it the same as a 4 door?
Old 07-24-2019, 05:00 PM
Originally Posted by PepinoBBB View Post
My car is a SW
Probably like the four door Tempests. Not any similarity to GTO's or other two door Tempests.
BONESTOCK GOATS
