Old 07-28-2019, 08:25 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Default VALLEY COVER BOLTS
I have missed placed my valley cover bolts, can someone tell me the specs of the correct size bolts?
Cheers
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
Old 07-29-2019, 10:07 AM
rustedgoat rustedgoat is offline
I had this info copy from some other threads on this site.
What year valley pan? Maybe someone can confirm.
1959-1967
pcv in rear
very small baffle spot welded on the inside
two different length bolts on this cover, 2" for the front and 2-1/2 for the rear.
1968-1972
pcv in front
this cover uses the 3-1/4" bolts front and rear
This cover has two pyramid shaped humps on top
1973-1979
pcv in front
has the egr hump in the center
This cover uses the 3-1/4" bolts front and rear
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 07-31-2019, 08:27 PM
Ozzmann's Avatar
Thanks rustedgoat.
