Old 08-07-2019, 11:33 AM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
Default 1968 GTO Ram Air
How do you tell if a 1968 GTO Ram Air Hood pan is aftermarket or original? Do they stamp part numbers in these?
Redline Design
Old 08-07-2019, 07:04 PM
PurelyGTO68 PurelyGTO68 is offline
My original pan did not have a part number stamped on it anywhere I could find.
Old 08-07-2019, 11:06 PM
Brewster's Avatar
Brewster Brewster is offline
Then maybe its not original? I dont know about you but GM seemed to punch numbers on everything. Maybe your looking in the wrong area?
Old 08-07-2019, 11:29 PM
brians's Avatar
brians brians is offline
There are no numbers on original top or bottom pans.
You will have a hard time telling the difference between aftermarket and original top plate from the shape and material.
The steel repro came out in 2001 and there has only been one maker so if it is older, it would have to be original. Most originals also have pit marks where the large foam seal goes from use.
“If you ain't first, you're last” - REESE BOBBY
