Old 07-02-2019, 06:11 PM
Scott Stoneburg's Avatar
Default 1st time assembling an IA II short block
Not sure why nothing attached to the last post. I'll try again.
Assembling a friends 535. I cleaned the block today and while going through the bolts and parts he brought to me I found these plugs. I have heard there are some screw in plugs that must be installed behind the bellhousing but I dont see where they go. The freeze plugs and screw in plugs are already installed there. The Bloch is supposed to be ready to assemble. Be picked it up from a machine shop because they had it for a very long time and were not working on it. ..any way..where do these go?
Old 07-02-2019, 06:16 PM
73 TRANSAM 73 TRANSAM is offline
Those looks like the screw in freeze plugs that go in the sides of the block. 3 on each side of the block. Also that is the option screw it plugs but it normally comes with a brass plugs that looks like it belongs to a plumbing section.
Old 07-02-2019, 06:37 PM
They are 1/2" pipe size with an o-ring to seal them. ..the freeze plugs are another thing that threw me off. They look to be press in plugs not screw in.
Old 07-02-2019, 06:41 PM
slowbird's Avatar
slowbird slowbird is offline
KRE blocks have press in freeze plugs, IA blocks are screw in. Maybe its a KRE block?
Old 07-02-2019, 06:51 PM
I'll look for more details.
Old 07-02-2019, 07:22 PM
The only definitive marking on the outside of the block is this "stamped" Indian Head.
ID:	515225   Click image for larger version
ID:	515226   Click image for larger version
Old 07-02-2019, 07:35 PM
hp 400 dave's Avatar
hp 400 dave hp 400 dave is offline
Looks like a IA 1, not a 2. The 1 had press in freeze plugs, at least my tall deck did. I don't remember where those plugs went.
Old 07-02-2019, 07:52 PM
I didnt know that. It may be an IA 1. My IA block says. ... IA XX. On the distributor pad area. This block doesnt.
Old 07-02-2019, 07:59 PM
Never had an AI 1 block.
But I'd look where most sizes of that type go?
Oil galley plugs, one for oil hole by the distributor.
(the one behind a freeze plug on rear of block is usually forgotten?)
Old 07-02-2019, 08:34 PM
77 TRASHCAN's Avatar
That's what I was thinking, the pass side internal plug that seals the oil galley, but then, why are there so many of them???
Shut it off
Shut it off
Old 07-02-2019, 08:47 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's an Indian Adventures (IA1) block you are describing.
Go fast, see Elvis!
Old 07-02-2019, 09:15 PM
I was thinking one in rear, 2 under cam timing gear (usually press in on stock block) one for the hole by distributor.
Old 07-02-2019, 10:47 PM
Richie Hoffman's Avatar
Those may not be for the block they look like the plugs for a custom aluminum oil pan to access the bolts or studs inside pan
2008KRE Q16 Winner
Old 07-03-2019, 06:47 AM
mysticmissle's Avatar
look like hydraulic plugs to me. Could be what richie says, I have a pan like that and it was reg pipe thread/plugs.
Should be a good block, i had no problems with mine. What is bore size? Make sure you check the hole where the clutch rod would thread into. I have heard they can be thin there and leak. Mine did not, but thought i would mention it. Also, anything above 4.375 bore, you should have it sonic checked,as there is some casting shift around the 6/8 5/7 cylinders, that may require a sleave at bores above 4.38
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-03-2019, 06:53 AM
Thanks for the help. I guess they could be from something other than this block. The owner just brought me everything he got from the previous owner/machine shop.
Old 07-03-2019, 05:52 PM
aaronman aaronman is offline
Agree with Richie. Those look exactly like the plugs that are used to access my Moroso custom oil pan bolts.
Old 07-11-2019, 07:13 PM
AG's Avatar
AG AG is offline
God bless Dick Duclow.
Old 07-11-2019, 07:25 PM
mgarblik mgarblik is offline
X2 for Mr. Duclow and Tom as well. The tradition has been carried on well by Frank and Bob, All Pontiac. As far as the plugs, I have built 3-4 IA I's and none of them had any plugs with O-rings. All the plugs were pipe thread.
Old 09-08-2019, 08:41 PM
Finally got the pistons/rods in. Have to throw out a big thanks to Scotty G @ Scotty's Race Engines in Spring Hill, Fl.
Checked deck height, got the cam degree'd in today, rings filed to fit and assembled. After I took the pics I put the oil pump and windage tray on. Next up is just to fit the oil pan, and timing cover.
ID:	519734   Click image for larger version
Old 09-09-2019, 03:13 AM
Dragncar Dragncar is offline
Looking good Scott. What kind of rods are those ?
