Old 08-25-2019, 09:47 PM
Default Filler part on top of core support material?
Is the material metal or plastic on the original filler that sits on top of the radiator support ? I see the new ones they sell are plastic.
Old 08-26-2019, 12:47 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
I want to say the originals were fiberglass, but I'm not sure. Hopefully someone with an original one will chime in.
I put the plastic re-pop unit on my 72 LeMans about 5 years ago, and I luv it. Makes a nice tool tray when working under the hood. I'll be installing one on my 71 GTO soon for the same reason.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 08-26-2019, 11:02 AM
The filler panel was originally injection molded plastic. Early reproductions from 25 years ago were of of a smooth (finished) top fiberglass design. The last 10 years reproduction is an injection molded plastic piece.
The large plastic filler was first introduced into production right after the Fall of '70 Strike & was installed on 455 & 455HO cars. It was not used on any early 71's. Have yet to run across an original 400 engined '71 or 72 400 car that originally came with the filler piece. I would love to run across a time capsule condition '71 400 3.90 rear GTO to authenticate, but that combination, only a very few were made. Original 350 T-41 cars did not get the filler either.
Old 08-26-2019, 04:51 PM
Great info, OPH. Thanks for posting!
Eric "Todd" Mitten
Deuteronomy 8:3
Old 08-26-2019, 08:33 PM
So you're saying my 72 Lemans with T41 never got the filler panel and it's not needed? I didn't get one with the car and parts. I hate to have to buy one if not necessary.
Old 08-26-2019, 08:38 PM
Yes, TJ, should not have originally had the filler piece.
Old 08-26-2019, 08:39 PM
Woohoo. Thanks for the info. Odd thing is, the assembly manual shows it. So it does get confusing.
