Old 04-25-2023, 09:26 AM
Stan65 Stan65 is offline
Default 73 F-Body female front seatbelt assembly
All,
Looking for a late 72-73 F-Body female front black seatbelt assembly, the one with the sleeve. I just need the one piece, but will consider more. I do not care if the buckle has exploded. The sleeve on mine is crumbling.
Old 04-25-2023, 11:51 AM
I had more in stock than I knew...altho not sure what year exactly and mostly back seat...could be '74
ID:	611429   Click image for larger version
Old 04-25-2023, 01:54 PM
Those look a little different, the buckles on some of them are definitely different. I “may” be interested if I cannot find the correct one.
Thanks for the quick reply
Old 04-25-2023, 04:13 PM
no worries...stuff just sitting around anyways
Old 04-25-2023, 05:06 PM
unruhjonny's Avatar
If my memory serves me, the 1973 (and likely late-1972) used a thicker/hard sleeve for the front belts - this tends to become brittle over time.
In the following picture, the belt on the far left is probably what the OP wants (even though it's a 1974 with a thinner sleeve):
I believe that the rear "female" belts (second and third from the left end) would work, but are lacking any kind of sleeve - and lack the seat belt buzzer wiring.
The "male" belts front and centre and rear/right are the 1974 shoulder belts;
For 1973 (and later 1972) the front belts still had a separate lap and shoulder belt, but unlike 70-72.5 there was only one female belt, and the lap belt had provisions to interlock the shoulder belt.
I believe that the "male"belts centre/rear are rear set lap belts.
I do not know what the belt is on the far right.
I used to own a 1973 Formula that I found for my brother, but it's back in his possession;
Shortly after he got it back on the road one of his belts popped apart, and I became acquainted with the term "exploding belts" - which these are.
I believe that for 1975 the belts once again changed, and were essentially carried forward to the end of the second gen run.
1970 Formula 400
Old 04-25-2023, 05:15 PM
Unrahjonny,
I agree the rear belts seem to have the same buckle. I only really need 1 correct sleeve.
Thanks.
Old 04-25-2023, 09:55 PM
The original molded plastic sleeves are nearly always missing. Still existent, they are often stress cracked. I'm setting in a similar situation on the front female belts for my late build '72 T/A, as well as late April 73 built T/A. Have pretty much decided to cut down a pair of new aftermarket molded plastic sleeves & use them on the '72. I've chased a few Irvin seatbelt components for the '72 for many years, & even being heavily networked, its not been easy.
BTW, exploding buckle style seat belts were not used in late '72 F-body's.
The exploding buckle belts were, however, introduced in late 72 model A-body's. Have a complete set out of a super low mile 72 Lux LeMans parts car. Have also sold & traded off a BUNCH of exploding buckle style female belts over the years. At least two different suppliers actually made exploding buckle style belts for GM.
Old 04-25-2023, 10:51 PM
Is that one with the wire sticking out the sleeve you speak of?
Old 04-26-2023, 12:29 AM
unruhjonny's Avatar
that wire is a part of the seat belt buzzer system.
1970 Formula 400
Old 04-26-2023, 12:35 PM
That system can go to heck...is that plastic thing surrounding it a sleeve?
Just curious.
Old 04-26-2023, 12:37 PM
unruhjonny's Avatar
it can be annoying, but it's easy to defeat.
1970 Formula 400
