Old 11-30-2020, 10:55 AM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
Default parking brake pics?
need some pics of parking brake system,77 T/A.I pulled every thing off without thinking..does it use a rod to equalize the cable on the pass side? I have 2 rods and not sure if or which one to use.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 11-30-2020, 09:46 PM
Grand73Am Grand73Am is offline
No rods are used. Here's a pic. There's one front cable, the curved equalizer in the center, and the connector that joins the 2 rear cables.
PARK BRAKE CABLE ORIGINAL ROUTING by grand73am, on Flickr
Steve F.
Old 12-01-2020, 03:05 PM
awesome,thanks,i bought a complete cable set,includes all the hardware ..
Old 12-01-2020, 10:26 PM
Great pic. Note the painted rings on the driveshaft to show type, and the 3rd ring from rubbing cable when loose!
Old 12-02-2020, 09:22 AM
TAKerry TAKerry is offline
Do you know what the code rings are on the shaft, also I assume it was left a natural finish from factory, hence why they are all rusted.
Old 12-02-2020, 09:38 AM
They are a combination of two painted rings, no doubt done at time of balancing. More often than not they are a light surface rusted ring where paint has worn off now surrounded by heavy rust from 40 yrs earlier. It says the colours on the build sheet, many of the later years were Brown-Brown or Brown-Yellow perhaps.
