Old 11-18-2020, 02:35 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default Where do I begin? 1970 T/A
1970 T/A: Problem; the tail lights and the brake light always stay on. The tail light harness, the headlight switch and the turn signal switch are all new and recently replaced. The ground wire to the trunk latch area is clean and tight. (all of the headlights and parking lights in front work correctly) Where do I start to see why the lights are always being powered up? There is no trunk compartment light in this car. Thx.
1970 T/A
Old 11-18-2020, 03:22 PM
72projectbird's Avatar
The fact that the brake lights are constantly on makes me believe it's the brake light switch. I'd check there first.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-18-2020, 04:34 PM
johnta1 johnta1 is online now
Agree.
Unplug the wire connector at the brake switch and see what it does.
The front lights work normally, like off when light switch is off?
How about when brake is pushed, front come on?
When light switch is off, the rear lights are still on?
Check the body connector going to the back half also.
Old 11-18-2020, 04:46 PM
Transamric's Avatar
Are the rear side marker lamps staying on too?
Old 11-18-2020, 08:33 PM
dpoltzer's Avatar
Default update.
I unplugged the brake light switch and tested the connector. The orange side is always hot and the white side is cold. Once disconnected, there is now no power to any of the tail lights. When I plugged the switch back up to the connector, I used my test light to the switch and noticed that both sides of the switch are always hot with the plunger (on the switch) both released or pushed al the way in. I believe this proves that the switch is not shutting off power ever. I will replace the switch . Sound about right?
1970 T/A
Old 11-18-2020, 08:40 PM
Sounds good to me.
(meaning switch is bad)
Old 11-18-2020, 10:30 PM
Sounds like the switch is toast.
1987 Grand National
Old 11-19-2020, 07:21 PM
dpoltzer's Avatar
Default Good news bad news
Good news:I replaced the brake light switch and now the tail lights only illuminate when you activate the H.L. switch. Bad news: the brake lights do not activate at all. All 4 bulbs are the two element 1157s. Is that the correct bulb? Also, when the brake light switch plunger is relaxed/extended, only one side of the switch is hot. Shouldn't both sides be hot. Thx.
1970 T/A
Old 11-19-2020, 07:44 PM
Transamric's Avatar
Yes, 1157 (or 2057) is the correct bulb. Have you double checked that they're Ok?
Yes, with the switch plunger fully extended, both with connectors should be hot. Bought a defective switch?
Old 11-20-2020, 04:21 PM
Formulabruce's Avatar
Your 4 way flasher could be shorted. This can cause this symptom.
Old 11-20-2020, 04:51 PM
dpoltzer's Avatar
I replaced the new switch with a new one from Napa and they are working properly. What are the odds of getting a bad switch!! Thanks.
1970 T/A
Old 11-20-2020, 06:56 PM
jerry455 jerry455 is offline
Probably greater than we all think. It seems as quality on many parts have deteriorated.
