How to straighten minor weld warping?
I do have some what I'll call minor weld warping only along the seam length and not full length, just a few areas in the quarter panel skin.
the large panel has none and came out great. so iv'e since read that you do want the gap fit as tight as possible so I did good there after all. I'm new to working with steel like this, can it be hammer and dolly removed/straightened? should I heat it up then hammer and dolly? do I use the stretching/shrinking hammer? I'm going to go even slower on the drivers side skin and see if I can achieve no warp. I may have caused it during grinding of the weld and overheated it not paying enough attention. any help is greatly appreciated. thanks |
Unfortunately I have never had good results leaving no gap between the panels and having no warping but maybe that's just me. I have had success using a shrinking disk on a grinder and also using a hammer and dolly at times. I have an Eagle stretch/shrinker that works awesome that I picked up from a body shop going out of business.
1969 GTO street strip project 11.1 forged 461, highport heads 1995 Trans-am 420 ci sb 14:1 compression 9"ford 9.89@132 1.34 60ft SOLD! |
I purchased one of these shrink disc kits from these guys and it works great after a little practice. You owe me a beer!
https://www.youtube.com/watch?v=rt07pLebQwQ https://www.wolfesmetalfabrication.com/sdisc.html |
Smack your welds before you start trying to straighten the sheet metal.
The welds themselves shrink and pull (distort) the sheet metal. Hammer and dolly directly on the welds is where to start. As soon as you hammer & dolly (stretch) or use a shrinker on the sheet metal, you may have a hard time recovering. I don't claim much experience but when I filled in some holes in my fender and didn't understand the weld shrinkage I made a mess that took a long time to correct. I bought one of the shrinking discs and it worked well for me but I think I could have avoided the need for it if I had just planished the welds as I went along. Here's a good explanation of monitoring shrink along a seam and relieving by planishing (randomly snagged online, I'm sure there are others): https://www.bangshift.com/forum/foru...hing-mig-welds |
X2. Planish your welds.
Don |
thank you very much for the tips.
am I to late to planish the already ground down weld seam and should go straight to a shrinking disc? I have never even heard of a shrinking disc, it appears easy to use. although my warps are only along the seam itself no large areas. should I use the hammer that looks like a meat tenderizer when using the hammer dolly method? silly questions to those experienced I know, but if I can get steered in the best direction I can handle it I believe. uncharted territory for me. |
You need to stretch, not shrink. Planish your weld line with a hammer and dolly. Regular hammer, not the meat tenderizer shrinking hammer.
Don |
The Following User Says Thank You to dhutton For This Useful Post: | ||
Yep, while welding metal expands, but it shrinks to a point smaller than before welding as it cools. You need to planish the welds to expand it again, then see where you are.
Torch and a wet rag
Yep ... I've also heard that people use heat and quenching to shrink metal ... but I'm not sure how much that applies to weld beads which have already gone through the heat induced expand/shrink cycle before. It can work well on mid panel lumps and bumps though.
Torch and a wet rag will shrink and distort it further. Wrong direction. Stretch it with a hammer and dolly.
Plenty of videos on weld planishing on YouTube.... Don |
thank you for the replies.
I completed the drivers quarter today and I did it much differently. much slower, moved around even when grinding the welds. only a couple spots need the hammer and dolly treatment. I have not got into it yet, but did a small spot on the passenger side and it worked. I'm going to enlist my son to help with holding the dolly before I get after it. I'm going to get a bag of steel shot to hold while hammering, thinking that will work real well? maybe better than a dolly? |
Don |
Hammer & dolly might eventually do it as it thins the metal and probably will oil can it in another spot. |
Maybe you could find some VHS tapes on basic sheet metal welding etc on eBay since you have an aversion to YouTube. The bangshift link posted below is also an excellent tutorial. Don Last edited by dhutton; 11-30-2019 at 11:38 PM. |
Hehehe ... maybe planish it with a rock too Hammers are too modern edgy.
H & D
It did work.
wanted to drive on with it but I was not comfortable reaching over in the trunk with the dolly and hammering both, slipped a little and dinged the quarter a little so i'm waiting on getting one of my sons to help. obvious i'm no expert but I don't think i'll create any canning. the warps are not very big. i'll be taking it very slow and carefull while doing it, i'm proud of my quarter skins! ha u can see in the pics there are no big warps etc. literally just at the weld. and not full length. just here and there. wish I could have slowed down like I did on the drivers side. I get all excited and think I can get away with it. (rookie syndrome!) Last edited by JUDGE3; 12-20-2023 at 10:59 AM. |
Can you skin a door with no filler? That was taught to me by an old black guy. I did not learn from any "videos" but from old timers who were masters of metal. More people should try it, they could actually learn something this interweb and its village idiots & Super Heros cannot teach. People today believe everything on the internet. LOL! Good luck in the real world - https://www.youtube.com/watch?v=bufTna0WArc Last edited by Chief of the 60's; 12-01-2019 at 10:51 AM. |
Maybe techniques were different back then due to different processes? Everyone pretty much mig welds panels now days but in the 70's I think there was a lot of oxy/acetylene welding or brazing being done? |
I’m guessing you’ve never learned a thing from anyone because you knew it all at birth. Troll on... Don |
The Following 4 Users Say Thank You to dhutton For This Useful Post: | ||
