Old 01-28-2023, 10:37 PM
jamesq's Avatar
jamesq jamesq is offline
Default sedan/wagon window sweeps?
Does anyone know of a source for 63 wagon window sweeps? They look like squeegees and attach to the door window frame outside the window. I need the ones for the back doors.
Thanks,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 01-29-2023, 02:21 PM
misterp266's Avatar
Default Wagons are so easy!
If you find a source please let me know!
Ames might have them as a set. Sometimes they have things not listed in the catalog. They list a set for every different combination except a sedan/wagon. I saw a reproduction set on eBay once but didn’t buy it at the time. Wish I had now!
" Darksiders Rule "
Old 01-29-2023, 05:13 PM
jamesq's Avatar
I'll check with Ames tomorrow.
More wagon unobtanium.....
James Q
James Quayhagen
Old 01-29-2023, 06:26 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Have you tried Steele Rubber Products?
The Following User Says Thank You to GtoFM For This Useful Post:
Old 01-30-2023, 06:33 PM
jamesq's Avatar
I called Steele, they do not have exact fit, but their sales rep said the product below can be cut to fit:
https://www.steelerubber.com/beltlin...rip-70-1121-61
I ordered a pair, so maybe I can make them work!
Thanks again,
James Q
James Quayhagen
The Following User Says Thank You to jamesq For This Useful Post:
Old 01-31-2023, 10:07 AM
GtoFM's Avatar
Steele Prods. is pricey. I have not used them yet but they are at the top of my list when I get to that point, so let us know how it worked out. Ck out their videos too.
Old 01-31-2023, 04:10 PM
jamesq's Avatar
They did seem a bit pricey ( 2 x 3' lengths, about $100 total), but if they work they are worth it!
James Q
James Quayhagen
Old 02-03-2023, 12:54 AM
alleyCat alleyCat is offline
Repops.com
They are probablynthe same as Chevrolet but call and ask if not listed. I sent them samples of 1961 Safari and they made them and gave me a set for helping them out
The Following 2 Users Say Thank You to alleyCat For This Useful Post:
Old 02-25-2023, 02:14 PM
jamesq's Avatar
OK, I got the product from Steele and put them on, here was my procedure:
1. I took a small dremel and cut the two screws from the front and back of the old sweep. I took a piece of folded cardboard and placed it between the sweep and the window so as to not damage the glass.
2. I pushed the old sweep down and out of the door.
3. I used these parts and watched the video that is embedded in the part description - https://www.steelerubber.com/beltlin...rip-70-1121-61
They had to be cut to length, I used a small chop saw.
4. I sanded and cleaned the inside of the door frame where the sweeps mount.
5. I used the 3M windshield adhesive referenced in the video, this is a VERY messy product. The upside is it is easy to remove after it cures!
6. I let cure undisturbed for 24 hours and cleaned up the mess.
The result is shown in the attached pic.
Good luck,
James Q
James Quayhagen
