Old 01-31-2023, 09:19 PM
4dblnkldude's Avatar
Default Modifying an AC dash harness for no AC
I have an original AC harness in my 81 and I want to modify it for no AC. Usually there is just the black wire going over to the motor. The diagram from ames does not show no AC and there is no black wire in the harness. Anyone have a diagram for that? Any tips for this?
Old 02-06-2023, 04:51 PM
Brentco's Avatar
Brentco Brentco is offline
You should be (assuming things didn’t change that much from 76) able to keep the same wiring to the blower as with AC. You leave in place pretty much all the AC wiring, and there may be one or two extra connectors to be tucked away.
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
Old 02-06-2023, 09:30 PM
Thank you. I did get it figured out.
