Old 12-07-2004, 06:29 AM
TransAm525 TransAm525 is offline
Does anyone know what type of adhesive is used to hold the door water shield to the door and where I can find this adhesive? The original is a white tar-like substance, which I would like to use again, but have not seen the adhesive listed in any of my restoration catalogs. Any help would be greatly appreciated.
Old 12-07-2004, 06:26 PM
firechicken2000 firechicken2000 is offline
I just used duck tape when i did mine. If the surface is clean, itll stick there forever.
Old 12-08-2004, 11:20 AM
alconk alconk is offline
Go to any body shop and ask for strip caulk by 3M. Basically the same stuff from the factory. I just used it the other day for the same reason and worked great. It's black in color and about the same thickness and width.
Old 12-08-2004, 12:33 PM
engineer engineer is offline
strip caulk by 3M is correct. it is not an adhesive.
Old 12-08-2004, 01:24 PM
mrrat1 mrrat1 is offline
I used the 3-m black windshield sealer caulk. It is very close to the gray stuff. Worked perfect. Dave K.
Old 12-08-2004, 10:04 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Strip caulk is what my 78 came with.
Skip Fix
Old 12-09-2004, 04:19 PM
you don't want a adhesive, just the calk. You never know when you might have to remove it again. My 81 came with the caulk.
Old 11-17-2019, 07:37 PM
allenga allenga is offline
Default Water Shields
What do you guys use for water shields. I see two different kinds on eBay. Thank you
Old 11-17-2019, 08:02 PM
Stuart's Avatar
Stuart Stuart is offline
Unless you're a stickler for originality, a sheet of heavy duty plastic dropcloth from the hardware will work fine. As mentioned in the earlier responses in this discussion, 3M strip caulk works well for sticking the water shield in place.
Old 11-17-2019, 08:19 PM
I want to buy one of the two versions on the market and use the 3m caulk
Old 11-18-2019, 09:25 AM
TAKerry TAKerry is offline
I used the water shields from Ames. They are much thicker than plastic, almost like a mylar. I was happy with them.
The Following User Says Thank You to TAKerry For This Useful Post:
Old 11-20-2019, 01:28 AM
Aus78Formula Aus78Formula is offline
I have the REM set, possibly what Kerry has. All cut and stamped to shape including cut outs for handles etc. Not installed yet, previously had thick black plastic sheet material by previous owner. Did the job but very crude, and it helps to be able to see through it to a certain point. They also used a contact glue to seal, which made it impossible to remove without tearing and still have the glue on the door inners to remove before paint. Use the gummy calk, as mentioned. It can be peeled apart and stuck back again when done, doesn't set.
https://www.ebay.com/itm/70-81-FIREB...-/180945793440
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 11-20-2019, 09:15 AM
I used a bead of clear silicone around the perimeter. Been so long but I may have not sealed the bottom thinking any moisture that got behind would wick out. Sticky caulk would have been great but I had silicone on hand. All it would take is a sharp razor around the edge to release. I figured the first one was on there for 40 years before it came off so I will let the next guy worry about mine!
Old 11-21-2019, 03:54 PM
highway star's Avatar
highway star highway star is offline
This is what I used also and applied aluminum tape all around.
Easy to take off if you have to adjust the glass, etc.
The Following User Says Thank You to highway star For This Useful Post:
