Old 06-26-2019, 06:05 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
Default Dash lights
My dash lights, all of them quite working. The small fuse for panel and ash tray is good. When I turn on the headlights there is power across the fuse, and to the brown or purple wire is attached to the fuse block. All instrument lights are out. Gauges work. Interior lights work. They dim and full bright. Brake , turn ,running , front turn , headlights work. Got any suggestions. Thanks John
Old 06-26-2019, 06:37 PM
higgenslake higgenslake is offline
I'm in the same boat.
Old 06-27-2019, 08:13 AM
Radman's Avatar
Radman Radman is offline
The common point for all of the dash lights will be the rheostat on the headlight switch. Try rotating it clockwise and counter clockwise. You may be able to find a spot where they work, or clean off the crud so that they work at more than one spot. If that doesn't work you will need a new headlight switch, or a high wattage fixed resistor to bypass the rheostat on the switch.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 06-29-2019, 09:28 AM
Well, I gave the switch, which was really dirty and dusty, a bath in electronic cleaner. I put it back in and there is one spot that the dash lights work. I guess it's time to search for a new switch. Higgenslake take it out and give it a bath with cleaner. Might get lucky. Know how to get it out? John
Old 06-29-2019, 02:30 PM
mechanickeith's Avatar
You can clean the rheostat with some fine black oxide sandpaper. I also use a pair of needle nose pliers to tweak the contact so it puts more pressure on the rheostat windings.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 06-29-2019, 03:30 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Headlamp switch
I have a extra 1963 Tempest headlamp switch. It looks to be in good shape.
Name:	1963 Tempest Lemans Headlamp dash switch_Used.jpg
ID:	515041   Click image for larger version
Name:	1963 Tempest Lemans Headlamp dash switch_Used~2.jpg
Peter Serio
Owner, Precision Pontiac
Old 06-29-2019, 04:18 PM
Yes, I have a NOS 1995138 ready to install.
Old 07-17-2019, 05:00 PM
Put in a new used switch all lights work fine. Thanks for the info.
