Front license plate
Need to mount a license plate on front of car. 67GTO.
Any suggestions on mounting bracket? I assume not a good idea to screw directly to bumper? Maybe use plastic hole inserts from parts store? |
Usually they are mounted using the square plastic inserts available at most parts stores and standard #14 (1/4 X 3/4) license plate screws. Ames carries them as a set B181
Any good auto parts store...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Jeff, those screws look correct for mopars. The correct ones should be a truss head screw.
If you don't mind drilling holes in your front plate you can mount it below the opening in the bumper for better air flow to the radiator....
NOS Factory Examples
This license plate package shown below is an NOS 1965 unit.
The Screws, Plastic inserts, and Rubber bumpers are also what’s used to mount the 66-67 front license plate shown in last pic. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Thank you, will order from Ames if the parts store set doesn't have the rubber bumpers.
Drag car is still down low but it's just got a cheapy chrome frame that doesn't matter.
So long, farewell. |
Dang. Yep. You want to sell it, and can I afford it? If you want PM me.
So, for '67, they had flutes on the side? Or, was it like this one?
Didn't even notice the flutes on the first one - mine were smooth sided. Here's the remains of mine. I saved the pieces and figured I'd try and maybe epoxy the back side or something.
OK, I don't have that version, but it's nice to put a date on it. My first picture was probably from the '50s. My avatar pic is from the 70's.
